Question about Achiever CCS5000 Shredder
Paper shredder hello I noticed you also need the plastic piece on your shredder replaced I was wondering if you ever resolved that issue and how. I also need to find that piece and am not getting anywhere. If you can let me know your outcome I'd really appreciate it. Thanks
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co. LLC they can help you in this regard!
Posted on Jun 12, 2008
Why won't shredder turn off automatically?
turn off and unplug; then turn over to see if there is any paper jammed in the shredder. MAKE SURE YOU TURN OFF AND UNPLUG BEFORE YOU WORK ON IT.
Clean out any jammed paper or plastic with a bamboo skewer or something like that. DO NOT put YOUR HANDS near the blades.
Jul 15, 2014 | Destroyit 2603 SMC Shredder
Paper Jammed
I have had the paper jam in my shredder which was not a Fellowes. I removed the power plug from the wall and used old dentist tools to pick the pieces of paper out of the shredding mechanism from underneath. I did not need to remove the cover. After extracting some paper try using the paper reverse option.
Apr 02, 2014 | Fellowes P70CM Shredder
Fellowes Powershred PS 60CC stopped working
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
Fellowes Shredder PS60
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Put too much paper in shredder- it jammed. I reversed the paper flow. Unit turned off. I've cleared the paper jam, but unit won't power up.
Sounds like the waste basket is not pushed all the way in. Your basket will have a piece of plastic (not in the middle, this is just a guide) probably on the right hand edge of the basket. This little piece of plastic pushes in on the safety switch. Take a flash light and look closely and you will see how this works. Take a Q-Tip and push in on this switch and see if it will power up.
Nov 15, 2009 | Royal 85X Shredder
I have a Fellowes ps-65c shredder. If I load a piece of paper, it doesn't turn on automaticaly. If I turn on the switch the shredder runs OK in both directions. I have cleaned both sides of the paper...
its possible the sensor has gone bad
you will need to UNplug the unit , then take it apart 9 screws then gently pry it apart with a screwdriver or butter knife
you could test this with a voltmeter, one side emits a constant should have 5-12 volts across this
the other side the reciever will change its voltage when you break the signal with a piece of paper.
also ive seen chunks of plastic break off from inside and as the teeth rotate the plastic can cut the wire
Jan 18, 2009 | Fellowes 3011001 Shredder
Will not shred will go in Rev
I just fixed a similar issue. My AS702MX shredder fell off my desk while I was emptying the basket. When I tried to use it after that it only ran in reverse, not in auto/forward (it was not jammed). This meant that the motor was still working. Since this shredder is so old, no longer under warranty, and not working anyway, I decided to open it up. I unscrewed the 5 screws on the bottom (that's all), then the plastic covering opened up. While looking at the shredder from the top (without the plastic cover) you will see a small black plastic trigger mechanism in the middle (this is what the paper hits to start the shred) this piece will push a copper filament onto the motor to complete the "auto" circuit. Well the fall had caused the plastic trigger to dislodge on one side... I popped it back into place and closed it up, and its working fine now. It was really simple to fix.
Aug 04, 2008 | Aurora Global AS702MX Shredder
Paper Shredder blades do not turn, even though motor is running
yes, it's the plastic gear that's shredded in this shredder. the drive gear on the motor is metal, as are the gears attached to blades. between is a single plastic gear which is chewed up the instant resistance is great enough. fabulous engineering. not a difficult fix, but where does one find the replacement part?
Jun 08, 2008 | Office Equipment & Supplies
Only runs in reverse
This is an issue with the paper feed sensor usually located in the center of the paper feed slot. If it is mechanical you need to jiggle switch in and out to free possible interference behind switch (piece of paper or debris) if it is an electronic sensor you more than likely have a bad sensor or pc board. You will need to contact manufacturer for any further assistance.
Mar 16, 2008 | Tech Solution TS-4500 Shredder
Where can I get new blades?
usually these plastic pieces break from the machine jamming you really should call Fellowes customer service at 1-800-945-4545 and speak with them. They may be able to resolve your problem with a little more information on your unit.
Mar 12, 2008 | Fellowes DM8C Cross-Cut Shredder
Achiever CCS5000 Shredder Logo
Top Achiever Office Equipment & Supplies Experts
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
