Question about Microwave Ovens
Lights dim when microwave runs. if runs more than 3 minutes it turns itself off and then resets after approx 10 minutes. I have had an electician here to see if it were the amps, it isn't.
  • 2 more comments
  • lc619 Apr 12, 2008
    the actual outlet is not being shared, but the ciricit is, with with 2 lamps and the overhead light in the kitchen. those are the lights that dim when micro runs.
  • kevin_taylor Sep 13, 2008
    just recently the power level on my microwave has been fluctuating. I do have some lights on the same circuit and when the microwave power fluctuates, the lights dim. I have had the same microwave and lights without any problem before, this problem has just recently started. the microwave is kind of old, maybe 8+ years. Do you think that the problem is caused by my microwave, or maybe I have a more serious problem with my home wiring.
  • William Miller
    William Miller May 11, 2010
    To clarify, if the house wiring is porper, I would first suspect the magnetron is failing and overheating, then tripping its internal thermostat.
    When it cools, it turns back on.
  • William Miller
    Assuming you only have 1 thing on that breaker - the microwave, then I would say your magnetron or high voltage transformer is failing.
    Did your electrician verify that the outlet is not being shared by anything else?
  • Microwave Ovens Master
  • 9,098 Answers
As long as those lights don't draw too much current, that will probably be okay.
The microwave may consume 1500-2000W (the model number tag or manual will tell you). Add that to the total of the wattage of the lights. Then divide that grand total of watts by 120 (the voltage) and that will give you current in amps that your oven and lamps draw.
Make sure your breaker is rated about 25% above that.
If that holds true, then then I would say your magnetron or high voltage transformer is failing.
If you can post back with your brand and model number I can give you some info on those.
Posted on Apr 13, 2008
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
Dec 21, 2015 | Microwave Ovens
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from
Dimming Microwave Light - Breville Support
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
I was cooking food for 1 minute and it just shut off after approx. 30 sec. There are no lights or power now. The outlet is fine. The unit is 4 yrs old.
Check your other appliance. You may have tripped a break. If they are all functioning, and you have no dead outlets in your kitchen, then the unit will need to be serviced. Hope it's the breaker.
a 1200w microware will draw 10 amps all by itself. Your outlets are most likely on 15 amp breakers, so it wouldn't take much amp draw from another kitchen appliance to trip the breaker.
May 11, 2011 | Dacor DMT2420SS Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Aug 05, 2008 | Sharp Microwave Ovens
Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Jan 05, 2008 | Neff H5470 Microwave Oven
Microwave Ovens Logo
1,005 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
