Question about InFocus LP 820 Multimedia Projector
Infocus LP820 - Turns on for 30sec then shuts down
Here's my problem. The projector starts up fine. Bulb strikes, picture is clear, all the fans are working. It works for about 30 seconds then the lamp shuts off. the screen shows "Retrying..." as it tries to, i believe, restrike the lamp. it starts to light up again and the lamp flashes on but then it all just shuts off to stand by mode. Can anyone help me? I've tried to talk to InFocus but they have been extremely slow getting back to me.
  • 2 more comments
  • klimmiks Nov 15, 2008
    I have the same problem. I noticed that mine strikes the light, i have about thirty seconds before it turns off without warning, and then the lcd panel reads "please wait, retrying" and then the lamp strikes again, turning on, and then shutting off after maybe 15-20 seconds. I thought that maybe theres a thermostat thats malfunctioning, but ive taken my projector apart and kept the thermostat cool while the projector ran, but the same problem still happens. It cant be the thermostat, i think, and i dont know what else to try.
  • Anonymous Feb 28, 2009
    I have the exact same problem with my LP820.
  • klimmiks Dec 09, 2013
    bad bulb. projectors start to act all kinds of funny with bad bulbs.
    bad bulb. projectors start acting all kinds of funny when they have a bad bulb
  • 74 Answers
Your lamp is the problem. When the lamp shuts down and turns back on thats usually an indication of a defective lamp.
Posted on Aug 21, 2009
  • 472 Answers
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Posted on Apr 11, 2008
LP820 projector powers up and all is well. After about 40 seconds to a minute it powers down. Control panel lights are on and LCD display says restarting. It comes back on for a couple of seconds and...
It could be are any of the led's blinking. ?
The other thing is to check the bulb is seated correctly in its connector.
Try removing bulb and reinserting.
Also clean the air filters at same time to make sure they are fine.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | InFocus SP-LAMP-012 Projector Lamp for...
I have an infocus lp820 with what looks like an blue ghost omage in centre of screen,i suspect optical engine or lcd panels
This projector is one I've worked on many times and you are correct. The lcd panels are burnt probably due to a hard shutdown not allowing the fans to cool the inner components done repeatedly over several sessions.
Mar 22, 2010 | InFocus SP-LAMP-012 Projector Lamp for...
Lp600 won't strike
If you replace the lamp but do not reset the lamp hours then the projector will not ignite the lamp to stop it blowing up the lamp and causing further problems. You can reset the hours without the image, on the x2 version you turned on for 1 minute then held down the volume up and down buttons for 10 seconds but all versions vary. The infocus website can usually tell you how though you may have to look for it a bit. Failing that try a firmware update available from the infocus website that should erase its brain so you can start again, hopefully you have kept the original leads it was shipped with to do this otherwise it will cost you another £20
Feb 11, 2010 | Office Equipment & Supplies
I have a infocus 4805 projector the bulb quit on me due to over heating i guess, any way it cracked and burnt out. I ordered a new bulb which i received and installed. I watched half a movie and had to...
first thing's first- clean the dust out of the projector with canned air. excessive dust and heat are death to a projector. then check the colorwheel. if you don't hear a high-pitched whir or you hear a buzzing, the colorwheel needs to be replaced. the lamp won't strike without it. next check both fans. you may need to take the top off to do it. if both fans don't spin properly, it will overheat. many times the larger fan (lamp fan) will burn out or the circuit that starts it burns out. next, check the new lamp. does it have black spot, bulges, or fogging? if so, you'll need to replace it. if you do have to, don't get the cheapest one from "bob's lamps" online. you get what you pay for. if all that is ok, then you have a bad power supply. it's rare that this model has ps issues, but it's not unheard of. you could get the part(s) from an infocus service center, or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 20, 2009 | InFocus ScreenPlay 4805 Multimedia...
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
Connecting Dell laptop to Infocus LP820
The USB cable doesn't transmit Video. You need to plug in the VGA cable. The "DVI" port on the LP820 is not a a DVI but a M1 Digital port and won't work with DVI unless you get a converter.
Nov 30, 2008 | InFocus LP 820 Multimedia Projector
Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Oct 14, 2007 | Optoma H56 Multimedia Projector
InFocus LP 820 Multimedia Projector Logo
1,122 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
