Question about Refrigerators
Refrigerator leaks water - Refrigerators
  • 2 more comments
  • prader
    prader Apr 11, 2008
    The 'new' solution you offered has been offered verbatim by another expert. Interesting.
    I did not expect a canned response, and do not want to pay for one. I provided specific information and requested same.
    Thank you for any help you can give.
  • prader
    prader Apr 11, 2008
    GE TFX26KR
    Thanks
  • prader
    prader Apr 11, 2008
    So sorry! Apparently I misread the header/post, and thought I was getting two copies of the same solution.
    My apologies!
    You can blister me here - that's what I did to you!
  • prader
    prader Apr 11, 2008
    You must live a bit south of New York - we just lost our snow!
  • 472 Answers
Open the doors all the way and check the seals near the inside closest to the hinges. Fridges are prone to wearing in these areas because they are closest to the frame and rub each time the door is opened and closed.
Also run something metalic around the seal to check the magnets inside the seal have not lost their strength.
New seals can be purchased, and there are places that will even come out to measure up the doors and refit them.
It could also be in need of regassing, though the first sign of that is normally that it will freeze over even in the fridge compartment.
Hope that helps =)
Posted on Apr 11, 2008
  • 1 more comment
  • Peter Thompson
    Peter Thompson Apr 11, 2008
    LOL, it's ok.
    Tomorrow the sun will rise and the Earth will continue to turn (and I have to mow the lawn..it just never ends LOL)
  • Peter Thompson
    Peter Thompson Apr 13, 2008
    Something just occurred to me while taking care of another problem. This unit has an icemaker correct. If it does, then chances are the water is leaking from the inlet pipe on the back of the fridge. Turn the water off at the tap and see if the leak continues.
  • Peter Thompson
    I live a little further south then New York =)
    I live in Brisbane Australia =) It's like Florida, but hotter and more humid.
  • 2,334 Answers
Could provide brand and model number of your appliance?
  • Jaime Hernandez Apr 11, 2008
    You can visit this website to have more ideas on what the problem could be. From the info there you will see if this is something you can do yourself.
    Let me know if you need further assistance.
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
My refrigerator is leaking water making noise and not making ice
It sounds like you have a leak (dry rot plastic tubing) on the ice maker water line. The leaking water is being picked up by you condenser fan near the water valves and probably causing the noise.
First, turn the water shut off valve to the refrigerator off.
You have a dangerous situation here. You need to stop the water leak. If the water leak gets to the electrical components of your unit, well it is dangerous!
You will be safe for now if you shut off the water.
You need a skilled technician to fix the problem. Just shut the water supply to the refrigerator off.
My name is Peter, retired Sears Service Refrigeration Technician. Pull the unit out so you can remove the lower back cover behind the refrigerator.
Oct 13, 2014 | Frigidaire Refrigerators
My refrigerator water dispenser leaks water in the water pan. The unit is about 10 year old. It just started leaking.How do I stop it from leaking?
If your water filter is located behind the grille at the bottom of the refrigerator the O ring seal is leaking. Happened to me. Get a new one.
Feb 21, 2014 | KitchenAid Superba Architect KSCS25INSS...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Maytag Wide by Side leaks from the refrigerator side
Hold the door switch in and you should be able to watch it leak.
Sep 10, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
