Question about Toshiba 51H93 51" Rear Projection HDTV
Toshiba 51H93 .
What would cause repeated horizontal output failure?
    Scholar:
  • 170 Answers
Check for cracks in the driver circuit, also i believe this maybe on of the models that had a kit that helped from driving the h-output to hard causing it to get hotter then normal.
Posted on Apr 12, 2008
Need info on mod kit for horiz output on Toshiba 51h93.
Do you have the part number, which kit do you need ?
Apr 21, 2008 | Televison & Video
Horiz output failure repeatedly?
can you please provide the TV model and part #.
Thanks
Apr 15, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Tv will not turn on even when reset button is pushed all you hear is a clicking noise
You need to replace the power supply on your set, this happen when horizontal output fail.
Dec 18, 2010 | Toshiba 51H93 51" Rear Projection HDTV
Sony KV36FS16 36" Timer/Standby light blinks 9 times.
A common cause is the fly-back transformer and HV multiplier assembly requires replacement. In some cases, but more rare, there may be a failure in the vertical amplifier output stage. There are some other support components that can cause this as well.
In some cases, if the CRT has a short it can damage the horizontal output stage area.
After replacing, the horizontal output transistor and its support components must be verified. Also, this type of failure will sometimes cause some failures in the main power supply.
An experienced tech who knows your model of set can verify the cause of failure, and replace the necessary parts. Take care that this type of service may be expensive.
Jerry G.
Jan 08, 2009 | Sony KV-36FS16 36" TV
Erratic problem
need to have the vertical output IC pins resoldered.
Jun 13, 2008 | JVC AV-27730 27" TV
51H93 HORIZONTAL OUTPUT TRANSISTOR FAILURE
What's the question???
If the transistor has failed, it has to be replaced. The cause must be found and fixed before applying back the power, or the new replacement will probably soon fail.
Jerry G.
Apr 16, 2008 | Televison & Video
Horizontal output transistor failure
check b+ comming from p/s. also check for blue flat caps in line with h-output circuit. if blown out the side. remove them from circuit. also might have a HVT goin bad. I believe this is also the model that might have a mod for h-out running too hott that requires adding a resister in the h-drive circuit. also try a heavier duty h-output.
Apr 09, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Will not power up
your problem is in flyback or high voltage section failure.
  • check horizontal output transistor
  • check fly back transformer.
  • check for supply to horizontal section as high voltage from power supply may create such problem
  • as this failure is due high voltage section so it is better to take skilled technician help.
  • good luck.
Oct 15, 2007 | Toshiba 27A51 27" TV
Toshiba 51H93 51" Rear Projection HDTV Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
