I have a jbl eon G15, which is now not powering on. Probably happened when being powered off, with the volume up... This has happened before in the store, and was fixed in minutes...I guess a simple fuse replacement. My question is, can I do this myself
  • 4,234 Answers
The fuse is accessible by removing the amp module from the back. The fuse location will be obvious. Replace it with the same type of fuse and you should be OK.
Dan
Posted on Apr 11, 2008
Eon 515xt - the 3 volume buttons move in and out about 1cm..is this normal or has something come loose inside?
Sounds about right to me. I have 2 eon G-15s. If you don't hear any cracking sounds you should be ok.
Apr 30, 2017 | Jbl Eon 515 Eon515 15 Powered Portable...
In turning up volume on eon g2 15 I get crackle sound and then when I mess with switch it finally works. The speaker has been used probably 10 times max. Its not a cord problem..perhaps its the control?
This model has very cheap pots. What really happens is the center pin on the pot breaks leaving the wiper that rides on the carbon track to lift, causing this problem. Use caution as this condition continues the pot will go bad enough to send max volume to the system causing severe damage to the speaker, and maybe the listener. THE GREAT OZ.
Aug 08, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I need a replacement volume control for jbl eon 15g2
Here is the link
http://www.fullcompass.com/product/368101.html
Mar 02, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl eon g2 problem!
Could be any number of things, the amp may be damaged (do you use these things at high volume?) but if you are only getting bass it could be a fault on the crossover circuitry. Could be a loose wire inside but the build quality on JBL is pretty good so I doubt that.
How long ago did you buy them? If it was recent you may be able to take them back to the shop, otherwise I'd seek a professional repairman.
Btw, did you check the fuse?
Dec 02, 2007 | JBL EON 15-G2 Powered DJ Speaker With EQ...
89 people viewed this question
 Grubhead
Grubhead
