Question about HP Compaq Presario V2000 Notebook
Replacing harddrive I have both a Compaq Presario V2000 and V5000. My V5000 got some slight water damage, it still works, except the computer thinks the backspace key is stuck, so it won't let me type anything. I was wondering if it is possible to replace the V2000 hardrive with the one in my V5000? Are they compatible? If so, I have been having trouble finding a site that will give me instructions on how to remove the harddrive from my particular models. I am not a computer wizard, so the more detailed the better. Thanks
    Problem Solver:
  • 14 Answers
You will have to do a reinstall of windows since XP will notice the hardware change the laptop models are not similar enough.
Posted on Apr 28, 2008
  • 77 Answers
Service Manual of V5000:
http://h10032.www1.hp.com/ctg/Manual/c00700903.pdf
Service Manual of V2000
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
yes the hdd of the V2000 and V5000 is interchangeable. it uses both IDE type hdd.
Posted on Apr 12, 2008
How can i reset my laptop. it wont turn on at all, and it has been a while. It is an old laptop and i just want to get the pictures off of it... is there a reset button or anything?
unfortunately no there is not but if you take it to your local specialist computer store they will be able to get the pics off for you.
hope this helps and good luck with the problem and by the way don't forget to vote for this solution.
Nov 10, 2010 | HP Compaq Presario V2000 Notebook
Bad keyboard. Intyping the letters skip around. Can't pin it down to any specific letter. Can I replace the keyboard?
yes you can replace keyboard $13 on ebay
http://cgi.ebay.com/HP-Compaq-Presario-M2000-R3000-V2000-V5000-Keyboard-/180543589690?pt=PCA_Mice_Trackballs&hash=item2a093c8d3a
Sep 02, 2010 | Compaq Presario R3000 Notebook
Compaq presario v2000 is dead!!!
Well oviously when you dropped it, it had done alot of damage. There is defenently something in there that needs replacement. I can't acctually see the inside of your laptop so i don't know what. Go see a computer pro.
Jun 09, 2009 | HP Compaq Presario V2000 Notebook
The mic. won't work when i install windows vista
some time windows have a problem and sound setting is also defect.you can check sound setting and then try.install driver sound if not exist
May 16, 2009 | HP Compaq Presario V2000 Notebook
BSOD when volume turned up on compaq presario v5000
This is usually caused by a fault on the Motherboard, nothing much will help in this case except replacing the motherboard.
Jan 30, 2009 | Compaq Presario Notebook
Compaq presario v2000 wont reconize harddrive
check that the jumper on the hard drive is set the same as the old hard drive i.e master or slave.
Jan 03, 2009 | HP Compaq Presario V2000 Notebook
V5000 problems
what you need 2 do is either take the whole laptop back 2 where you brought it or even the battery cause you have a faulty battery.
most laptop batterys last for at least 5-10 years and after that no matter how much you charge them up they alwayz seem to be flat.
so my suggestion is get a new battery or take it back to the place that you brought it from and than get it replaced for free as long as you have your recept.
Jul 06, 2008 | HP Compaq Presario V2000 Notebook
Virus killed my laptop
hello. do you have the soft ware that can with it .? when u got it. ? you can try to reinstall it. or get new software to upgrade it . up need to wipe the harddrive clean and start fresh copy.on your HARDDRIVE. !!! OR TAKE IT IN TO A SHOP AND LET THEM DO IT FOR YOU. GOOD LUCK.
Jun 19, 2008 | HP Compaq Presario V2000 Notebook
maybe you need a replacement keyboard. ihave it but in jamaica shipping would takeawhile
Apr 13, 2008 | Compaq Presario M2000 Notebook
My compaq presario v5000 shut down and wont restart
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
153 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
