Using external hard drive for running applications.
1. What should I look for in an external hard drive that I want to use to run applications?
2. What other options are there other than the external hard drive to keep from gumming up the work laptop?
  • 106 Answers
FOLLOWING THINGS U SHOULD KEEP IN MIND WHILE GOING FOR EXTERNAL HARD DRIVE :-
1. PURPOSE OF EXTERNAL DRIVE - MEANS U WANT TO KEEP THAT TO USE IT FOR BACKING UP OF DATA?
2. DO THE COST EFFECTIVENESS OALSO EFFECTS UR PURCHASE?
3. TELL THE SPECIFICATION OF UR PC TO THE VENDOR BEFORE U BUY A NEW EXTERNAL DRIVE, AS IT MAY NOT SUPPORT SOME TIME.
4. ..... MAYN MORE...NOT COMMING TO MIND NOW... :-)
Posted on Apr 11, 2008
Trying to copy backup from SimpleTecj 500 from XP to Windows 7
1. how did you back up? file by file or using a backup program?
2. does win7 see the external drive, i.e., does it show up in my computer?
Jun 07, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Tip
How to Install an Operating System on an External USB Hard Drive:
You may have an external hard drive you want to use for more than just document backup.
In this situation, you can install an operating system onto your external hard drive. By doing so, you will be able to run your external hard drive as a fully functional operating system.
If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup.
1) Plug your external Hard Drive into your Computer using the USB cable. Insert the installation disk for your Operating System into the CD/DVD Drive. Turn on or restart your Computer.
2) Boot from the installation disk. You may have to press a key once prompted to boot from the installation disk.
3) Accept the license terms and conditions. Read through these carefully if you wish to understand your legal rights as a user. If you disagree with these terms and conditions, you may want to purchase a different Operating System.
4) Choose your destination drive. Your external Hard Drive will likely be the E: or F: drive. By default, the C: will represent your main Hard Drive and the D: will usually represent your CD/DVD Drive.
5) Begin the installation. Your external Hard Drive will install the Operating System. You will now be able to run that Operating System off of your external hard drive.
Hope this helps.
on Sep 03, 2010 | Computers & Internet
Hello i have a dell mini 910 and it has no space on it. i've heard of dual booting. how could i save, install, and run programs from an external hard drive
using an external HDD doesn't require dual booting.
First connect the external drive, and copy files to the drive that don't require and applications to be installed (MP3s, Avi Videos, Pictures)
Then you can delete the files from the HDD, this will immediately give a boost in performance. Generally, most games run a an Atom powered system don't take a great deal of space, so moving applications to the external drive likely would not be gratly beneficial as keeping data files there.
Dual booting by the way, is the process of installing 2 operating systems on a computer and being able to boot to more than one version. (Windows XP and Vista for example) of Windows and another OS (XP and Linux)
May 07, 2010 | Dell Inspiron mini 9 - Black , Intel® Atom...
My external hard disc worked well until today. Now the external light continues to flicker quickly and the hard disc does not show up on my desk top. I have a mac running Mac OS X 10.5.7. The serial...
There is some thing wrong with file system on your hard disk drive.
Just unplugg it and wait for 1 min, Plugin again.
1) Go to Application -> Utility -> Disk Utility
2) You can see all the drives connected to the machine.
3) Select the drive from left side which acts as external and click on Repair disk button.
Sep 18, 2009 | LaCie Computers & Internet
How to install new hard drive
2 choices for you. Get the external to run the game or 2. Add a larger hdd to the system as a slave drive leaving the smaller drive as the master. If you go the 2nd route just make sure you buy a compatible hdd. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | HP Compaq d530 PC Desktop
Ejection Problem
Just because you are not using it does not mean that your computer is not using it ...press ctrl al and del simultaneously to get the popup task manager..then check the application tab.. if you see any processes running that originate from that external drive..select them and then select end task. then try ejecting your hard drive.. Let me know if that works for you...or if not.. I have a few other ideas that you can try... Good luck
Sep 24, 2008 | Western Digital External USB 2.0 80 GB...
Using a hard drive for running programs
Hi ambladybut
It's true, you CAN choose to install applications to a drive other than the usual default location of c:\program files\newsoftwareprogram
However---- the operating system will still need to know all about these applications. It will keep information about these applications stored in locations on the laptop's internal hard disk, including in your user profile directory (c:\documents and settings\youruserprofile (if you're using WindowsXP)), the system registry, and various other locations depending upon the software.
These applications will also install shortcuts for accessing them to the Start Menu and Desktop.
Finally, where they store their data (unless you configure them differntly) will also be saved to the laptop's internal hard disk.
So, whether installing the applications to an external hard disk will achieve what you are attempting to accomplish will depend upon your reasons for doing so:
(A) Do you want to use the external hard disk in order to save space on the laptop's hard disk? If that is the case, then using the external hard disk would meet your needs.
(B) Do you want to use the external hard disk for privacy or security reasons? If that is the case, then an external hard disk would not be the appropriate solution for you.
In the case of (B), there are other solutions. Rather than delve into them yet, let's find out what you would like to accomplish w/ respect to segregating your home and work applications. Then we can point you in the appropriate direction.
** We WILL keep working w/ you until all of
** your questions have been answered.
** Please, don't assign a rating to any of
** the experts' answers or recommendations
** until that time. Once ratings are assigned,
** the problem will be closed and we won't
** be able to continue to assist you.
** Once your question(s) have been ans-
** wered, please do, take a moment to rate
** the participants' solutions.
Thank you,
BJ @:)
Apr 11, 2008 | Computers & Internet
Using hard drive on a Mac
If the drive is empty, use disk utility to reformat the drive as HFS+. DO NOT DO THIS IF YOU HAVE DATA ON THE DRIVE!!! :-)
Dec 03, 2007 | Seagate 160GB 3.5" External USB Drive 160...
Maxtor External 500 GB Hard Drive
Hi, 1. "Is the data recoverable?" Yes but the manner by which it can be recovered can be either very expensive (their are firms whose specialty id data recovery) or none at all if you do DIY (do it yourself) or worst case not economical reasonable but recovery possible. I would assume that your would want to try DIY. 1.1 Run diagnostic on the external drive using scandisk, Norton Disk Doctor, Partition Magic's ChkDsk and/or Check Errors. Recovery can be done using a recovery software such as GetDataBack; or 1.2 You need an external desktop PC, a working knowledge of computer hardware. You have to disassemble the external HD and remove the actual HD. Physicall connect it to the 2nd PC (desktop) as a seconday Master either by IDE or SATA as applicable. If detected by the desktop PC in the bios, you should be able to work on it even if with errors; 1.3 If mechanical problem or otherwise, you may want to check out this posting > http://www.fixya.com/support/t162904-seagate_barracuda_7200_7_st380011a Hope this works out for you and/or give you some ideas. Pls post again how things turn up. Good luck and kind regards.
Aug 05, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
