Question about HP Photosmart C6180 All-In-One InkJet Printer
Scanning into my computer
I am unable to scan a document on my HP 7200 series onto my computer. How can I fix this?
  • BF001 Mar 01, 2009
    But I am using my HP C7200 over a wireless network. Ideas? Thanks!!
  • Anonymous Apr 17, 2009
    My printer, an HP Photosmart C6280 AIO worked fine for a time then went haywire! First it wouldn't print photos. Then it uninstalled itself. We fixed that. Now it won't scan. I keep getting a message that there is a fatal error in installation although it is installed. I was on the phone on three separate occasions with HP techs who uninstalled and reinstalled the printer then told me the problem was my USB cable although I can now print photos and letters. I just can't scan.
Did she say wireless?
Posted on Apr 09, 2009
    Guru:
  • 731 Answers
Try these steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : Hp Photosmart C7200)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
IF IT DOESNT WORKS THIS
1.Click start - >run then type "twain_32" click OK.
2.A window will open and click EDIT menu-> select all, then delete all the files and folders.
3.Click start - >run then type "services.msc" click OK.
4.Look for service called "HPZ PML Driver", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
5.Right click on "HPZ PML Driver" and click "Restart".Close the window.Click start - >run then type "%temp%" click OK.A window will open and click EDIT menu-> select all, then delete all the files and folders.If u cant delete them its ok, just close the window and go to step 6.
6.Disconnect the Printer USB cable, Insert the installation disk of your printer.If Installation wizard pops up, click on cancel/exit.
7.open My Computer, right click on your CD/DVD ROM Drive , then click "open".Look for folder called "UTIL" then look for folder called "CCC".There you will see a file that says "Uninstall_2". Double click on that file.
8.A run box will poppup, click OK, now you will see the command windows, hit enter the Driver that is necessary for comunication which are corrupted will be removed.
9.After that, restart the PC and Insert the Disk and install the printer.Connect the Printer USB only if the PC prompts you to connect.After installaton completes, check the scanner.
Regards
Riz
Posted on Apr 12, 2008
How do I scan a document
Depending on the PC operating system you could download the instructions for how to scan from this site.
Scan HP Deskjet 3050 All in One Printer J610a HP Support
Aug 25, 2014 | HP DeskJet 3050A All-In-One Printer...
How do i scan a document to computer
We need to install the printer Software on the computer.
If you have the CD that came with the printer you can do it from there or you can download it from the following links depending on your operating system:
Windows Vista:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-61479-4&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3575276
Windows XP:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-61479-4&lc=en&dlc=en&cc=us&product=3575276&os=228&lang=en
After you install the software open HP SOLUTION CENTER..
you will find the scan options over there..
click on either scan document
you will get the option to save it onto your computer..
once the scan is done you can view it.
the scanned document gets saved under My Documents under the folder My Scans.
it is really easy, trust me :)
plz rate if you find it helpful. THANK YOU
Sep 25, 2009 | HP Photosmart C5580 All-In-One InkJet...
Unable to scan a doucument onto my computer
Assuming you HAVE installed the software, and you're running Windows XP, I've seen this problem and the solution is on the HP Web Site here:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&custom_solutionid=rb20020000&docname=c01545804
Obviously you'll have to paste the link all back together in your browser, there are no blanks in it. Sorry for the inconvenience. Their description is bad for XP firewall, ignore the UDP 427 Inbound. HP doesn't know they are all bidirectional anyway :)
Dec 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Trying to scan document on HP Deskjet F4200 all in one series. When scanning small document from TIFF Image this is scanning through as 25.5 MB so I am unable to send this as an attachement to an email as...
Try lowering your scan resolution settings. Magazine quality is 300dpi. If you don't want to lose too much quality, open the file is a image editor and crop only the area you wish to send.
Nov 06, 2008 | HP Computers & Internet
Unable to scan
Make sure you have microsoft word installed i you computer.
But if you want to scan a document you can also scan it to HP Document Viewer.
First open solution center/HP Director and try to scan from document> then in the optin which says where do you want to send the scanned image> click on the drop down and check to see yu have the option of word> if yes select the option of word and try to scan.
If not Open HP Solution center/HP Director and go to settings> Scan settings> Scan to setup> Go to> Destination List> And click on Restore defaults and check to see if you have the option of word in the availabe list and front panel destination list> then click on apply ad ok and close all the windows and then try and check to see if you get the option of scan to word.
Sep 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
406 people viewed this question
Ben Johnson
