Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi Projection TV model WS-65513
The timer green light blinks all the time but the tv will not power on. We have unplugged it and pressed the reset button and nothing works. This has been going on for about three weeks now. The first time it happened for about a week and one day I noticed the light was not blinking and I used the remote and the tv turned on, however after about a week the power went off in the night and the green light started blinking again and will not stop and will not turn on. This time it has lasted for the last 3 weeks or so. If you have any ideas please e-mail me at vickie_moon@yahoo.com Thank you.
  • 927 Answers
Good Day;
The continues blinking 99.9 % of the time is four caps on your DM board. The caps are C9B01,C9B02,C9B10 and C9B11 they use 1000UHF the upgrade caps are 680 UHF- 35V. The board is on the very left hand side (from back).
I have performed this repair at least 50 times and it takes me still about 1.5 hours. If you are not handy and do not have a solder station, I would recommend that you call a factory authorized service dealer to perform this repair. With service call and ect. it will cost you around $550.00 and the repair can be done in the home, of course prices varies across the country.
Good Luck, Day, Big Irish.
Posted on Jun 18, 2008
premtech
  • 934 Answers
SOURCE: Mitsubishi WS-65611
Just from what you've described it could be any number of things. One of the more common problems is the convergence Ic8c00 Stk393-110 Mits. Part # 267p155010 and the fuse 9a04... On a scale of 1 to 10 and 10 being the most difficult the task is about an 8 to replace and trace test the convergence circuit. You can however check and see if 9a04 is open, and if so, then you know where the problem is and can be more informed when asking a shop about what they charge to repair this problem. Take a VU or DMM meter set on continuity and loacte 9a04. That location number will be printed on the board right next to the component you're looking for... Next test it for continuity. If you get no reading it's open and the convergence amp is the culprit. Hope this helps. Bill
Posted on Jun 06, 2007
techman
  • 3130 Answers
SOURCE: Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Posted on Jul 14, 2007
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-55859 rear projection TV with a convergence problem
This set uses a single STK-393-110 CONVERGENCE IC---I will tell you what is needed and what is involved in this repair.
The chip can purchased on Ebay for about 14 dollars plus shipping--On Ebay select search, then advanced search, and then search by seller--look for: sewsales55 (the company is called Suburban Electronics and is in Maryland--I buy a lot of parts from them.)
Info is coming and let me know if you have any questions here or there.
I do this here for free so if this has helped you give me a vote here.
SD TECH
Posted on Sep 20, 2009
Testimonial: "Exactly what I needed and wanted to fix my issue! Thanks!!!"
SOURCE: mitsubishi model # ws- 65513 flashes green power
Reset TV, wait a few minutes and try it.
Posted on Sep 24, 2009
tlm931
  • 273 Answers
SOURCE: Mitsubishi WS-55413 timer light flashing. tv will not power on
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
Posted on Oct 24, 2009
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
BLINKING GREEN TIMER LIGHT, TV WILL NOT COME ON
You can get the repair kit to fix the DM at the following link. Contains the parts and step by step instructions with pictures so you can easilly do it yourself.
http://servicemanuals.vstore.ca/
Jun 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Apr 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
