Question about Philips 42FD9954 42 in. Plasma HDTV
Power issue I have the 42pf9956/37. Same thing. Hit the power and it just clicks. I took off the back cover and tried the power and found the relay that was clicking. I have two blue relays in the middle of the board. I took a hair dryer and placed it over the relays. After a minute I tried the power and after 4 times it stayed on. Not sure why, but it is free. I won't turn it back off soon though. Why does this work??? Kevin
    Problem Solver:
The Philips Plasma TV have a problem with electrolytic capacitors going bad. I believe you heated some capacitors and your problem may return. If so, try replacing 2540 (100ufd@25v)
and 2508 (4.7ufd@50V).
Posted on May 06, 2008
Stereo clicking sound
OH dear! Lightening is not friendly with electronic equipment. A clicking sound is almost certainly the relays dropping the power supply out and then re-trying. If you are lucky you may only have fried your rectifier diodes. This, and any other fried devices should be obvious with a visual inspection. Sorry, not much help. Do you have lightening damage insurance?
Nov 23, 2013 | Denon AVR-3803 Receiver
Magnavox 37MF331D 37 inch won't power on with no led light
check the power supply board for swollen filter capacitors
Oct 15, 2012 | Televison & Video
The back pasenger electric window of my 2006 dodge ram 3500 deisel wont go up.both the switch on the door and the switch on the driver control door dont work. checked the fuse box but found nothing labeled...
hi, there is a relay for the windows. in the fusebox (s) there should be a relay for each window. these relays do fail (open circuit on switch side). the feed POWER side may be shorted. these circuits are hard to find the fault, but check all the door relays. the motor can stick and put heavy current to blow the fuse, if you leave the engine OFF and put the ignition ON press the other window and listen for this relay noise. a click can be heard to pinpoint the location of other relays. once you find these switch relays to determin if these are working and use this to put the rear window back up. gerry
Sep 13, 2010 | 2006 Dodge Ram 3500 Truck
No Power up. Has 3 relay clicks when you plug it in. No LEDs light up and no flashing code from the stand-by LED. Have service manual. Where do I start?
hello the best thing to do is turn the power off take the back cover off and visual inspect the boards in side get a good torch and check for any bulging capacitors burnt resistors if everythink looks ok then you will have to check underneath the boards for any try joints i hope this helps
regards
shaun
Feb 23, 2010 | Sony KP-53HS30 53" Rear Projection...
I replaced main power unit and and formatter PWB but I cannot keep tv on. It turns on, I hear some buzzing then a faint click followed by an immediate louder cllick and powers off alltogether? Need help...
If power supply is good and voltage measures out ok. Also check any relays or capacitors.If LCD, check caps, if projection, check bulb and high-voltage transformer and flyback with a voltmeter.
Capacitors are the most common reason for failure in today's electronics.
Nov 15, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Acer Aspire 5600 wont turn on.
Ther is only one thing that you have not tried I think. Try to remove the CMOS battery from the motherboard for about 15 minutes and reconnect it. It's a small lithium battery.
Nov 25, 2008 | E-Machines T1360 PC Desktop
Samsung le32r74bdx 32
i have a $1256 samsung 40'' lcd i have had it for about 1.5 years..just long enough for the warranty to expire..i went to turn the tv on like nomal but all i got was a ed blinking light..and than it would go out after the relay inside clicked a few times.tryed all the to fix it my self..new power cord,diffrent outlet,letting it sit unpluged for 24hrs.ect..finally i took it off the wall took the back off to see if any fusses were blown out. nothing it all looked good to me.so i took my air commpeser to it and blew the whole thing out..put it all back together..and it turned on red light was off and just a hint of light at the edge of the screen...so i was like ok and began to play my ps3 and after about 45 min i just shut off ..nothin would work back to the blinking ed light.i have not messed with it for 3 weeks and yesterday tryed it again.nothin but relay click and red light...so i hit my tv at the bottom by the switch and i came on...i couldnt believe my eyes..it was short lived after watching it for 5 hrs tuned it off and went to bed...in the morning i ran down stairs to turn on my tv..but yet again black..i was not going to spend $300 to $700 to get it fixed..so to day i got my air commpeser and blew it out again..this time i was messing with the power cord right where is hooks to the tv and the red light stayed on solid like it was in stand-by so i pressed the power button and it turned on..so long story..check the power cord and blow out you tv.."but be carful"
Aug 09, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Philips 42FD9954 42 in. Plasma HDTV Logo
496 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
