Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Ensignia Model MDE6657BYW stopped...
The light comes on when the door opens...goes off when it's shut. Lint trap is replaced and circuit breaker is in the on position. The timer doesn't tick...and pulling the start doesn't do anything. It was working stopped working. Is there an internal fuse that I can located and replace or will I need a service man to the house?
  • philjosie Apr 29, 2008
    Maytag Ensignia Model MDE6657BYW sort of the same unit overheats and trips the circuit breaker. I called Maytag and was told to call a service rep. I called Sears, from whom I bought it, and was told that for $65 they could send out a service tech and "of course" there would be other charges for labor and parts!
  • ashmc Jul 08, 2008
    I have the Maytag MDE6657BYW dryer. I had the exact same problem (dryer stopped in the middle of a load, light comes on, pulling start dial does nothing) and I replaced the Thermal Fuse (part # 307473) and the High Limit Thermostat (part # 303396) and it did not fix the problem. Has anyone found an alternate solution?
  • 1,073 Answers
Yep there is and it is on the right side of the heater housing, it is connected by 2 white wires, you have to remove the heating element toget at it part is a la-1053
Posted on Apr 11, 2008
Maytag centennial dryer isn't collecting lint in filter trap
is any air blowing out the back of dryer?if the blower wheel is broken or clogged with lint this could cause this also the belt could have broke,open the door to dryer,hold the door switch in with your hand and start it,if it runs but the drum isn't spinning the belt broke.if the lint isn't in the filter there isn't any air movement,also next time send the model number
Feb 04, 2018 | Maytag Dryers
Does the maytag dryer have a reset button. The dryer was working fine then just stopped turning on.
No, they typically don't have a reset button. But they do have safety switches which can fail. Usually there is a microswitch on the door. When the door is open the dryer won't start. Do you have power at all to the dryer? Do any lights light up? If not, you may have tripped your circuit breaker to the dryer and need to reset them. Typically there will be two breaker switches tied together to move as one in your power panel for your house or apartment. If you are not sure the breaker has tripped, it won't hurt anything to switch them off and then back on again. If this does not help, you likely have a failed switch or relay in the dryer that will need to be replaced. Also check that your lint trap does not have a switch which will prevent to dryer from running if you have too much lint in it.
Nov 04, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag Bravos XL MCT will not start, light is stuck on "detecting" under airflow. All vents and lint trap are clear.
If the vent output is clear and lint trap is clear, then there are a couple of more hidden spots that air can get backed up.
First off, unplug the dryer before doing any of this. There's a lot of current to that plug, and getting killed is a really bad way to detect a bad wire or to identify where the heater coil inlet is.
  1. Inlet to the heater area. Laundry rooms have lint in them. All the air that gets blown out the back has to come from somewhere. make sure you don't have a clump o dust bunnies on another section of the rear panel.
  2. The blower motor itself. The lint filter can't get everything. The first time I took the back off my old Kenmore and opened up that area after the lint trap, it was like looking at a chalkboard eraser. Solid lint. The fins in the blower were packed tight with more lint. Cleaned it all out, and it ran better than it had in years.
  3. If the wall/floor connector for the vent hose goes anywhere but straight through the wall to outside, look down the hose and clear what you can, then go outside to the outlet and make sure it's not blocked, jammed, frozen shut, or what have you. Clean what you can from that end too.
    Hope this helps!
Good Luck!
Sep 10, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My Maytag Ensignia electric dryer quite heating. I cleaned front and back lint traps. I'm trying to find where the heating element is at. I was told to remove the drum through the front to get to the...
I worked on one not long ago and made some photos.
You pop the top using a putty knife and remove the front.
The element is mounted in the rear and is held in place by 2 screws. The thermal fuse and high limit are also mounted on it.themobilian_2824.jpg
I worked on swapping out a motor and took some photos:
Maytag Ensignia motor replacement
Aug 16, 2011 | Maytag Dryers
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
Jan 21, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Doesn't heat and dryer light no longer works
make sure you have power to BOTH legs of the 220v.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
570 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
