Set up This is Dirty Farkie and you were kind enough to try and assist me with my dvd / cd player in my desktop. You indicated concern with the IDE connection and I feel you are right on the money. You recommended that I go to setup and check to see if the bios is enabled or not. How to I diagnose this. Where is set up and what am I looking for. Your assistance is greatly appreciated. Thanks.
    Sergeant:
  • 221 Answers
When you start your computer, read the message that flash quickly at the top and bottom of your screen. There should be a message telling you to press one of the 'F' keys to enter setup, usually F2 if you have windows XP.
When you get into setup, your mouse will no longer work, so you will have to use the up, down and side to side arrow keys to move your selections. Look for 'drive configurations' or something along those lines, highlight it, click enter, and just check to make sure that the cdrom drives are listed and that it does not say disabled next to them. If everything looks good press the escape key, arrow over to exit, hit enter, then save and exit, and enter.
The setup screen is tricky to work with, if you change a setting it could cause your computer to run differently than you are accustomed to, so if you are not comfortable just try replacing one of the drives to see if it works, if it does then you do not need to go into setup.
Any other questions please ask!
Posted on Apr 11, 2008
Panasonic Portable dvd/cd player model #DVD-LS90 The player turns on and tries to read the DVD. However, it no longer spins so the DVD cannot be read.
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Panasonic Televison & Video
Do I set up ide hardrive as master and ide dvd/cd burner as slave?
Yes! The only time you might reverse that is if your computer failed to boot up from the hard drive.
Feb 23, 2014 | E-Machines etower 633ids PC Desktop
This pioneer DVD player is rejecting all disks. Kindly assist
Most dvd players (or anything with a laser) will fail eventually. If the laser failed, there isn't much point trying to get it repaired.
Oct 21, 2013 | Pioneer DV-420 Black 1080p HDMI...
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
The player will play dvd and cd. Will not burn
  1. Check the DVD format,maybe the dvd your trying to burn is not supported by your DVD writer
  2. Check the surface of the disc.If is dirty or scratched
  3. Make sure that DMA is enabled on your IDE channels in the "Windows Device" manager(right click on My Computer and select Properties.Hardware->Device Manager )
  4. Uninstall every DVD program you have
  5. Reboot
  6. Verify that your hard drive has enough empty space so it could burn something
  7. Install the program
  8. And try again
Jan 19, 2010 | Gateway Computers & Internet
Have rs480m motherboard need the 2pin sequence to hook up the hard drive ''e-machine t6520''
I assume you are looking to connect another hard drive in your computer.
Most desktop computers have two IDE controllers.
The 1st controller will have the "C" drive set to Master (MA) and there maybe another drive CD or DVD drive on the same IDE cable, if so the drive will be set to Slave (SL) or if you intend to install a drive on this cable.
The 2nd. IDE controller and cable can have hard drive or CD/DVD drives too but the drives must be set to either Master or Slave - BOTH drives in the one cable CANNOT be set the same.
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
Nov 29, 2009 | E-Machines T6520 PC Desktop
Divided picture on Protron PD-800 DVD/CD/CD-R PLAYER
Hi Alberto,
The split screen (identical display left & right) indicates that your DVD is on Progressive Scan.
P scan refers to progressive scanning mode and is not an indication of something broken but rather is a feature. What you can do is look over your remote and check if it's got a PS or PScan button. Pressing the button should revert to the single display. If there is no such button, pls check your menu or settings and should be there somewhere. At other times, there is a small hard switch at the rear (or front) of the player itself just for this purpose.
On your concern for no color, determine the color system of the disc you're playing, the setting of your DVD player as well as the color system of your TV. They should be the same. The 3 systems are NTSC, PAl and SECAM.
Hope this be of some help/idea. Pls post back should you have other concerns.
Nov 11, 2007 | Spectroniq PD-1100 DVD Player
Cd Drive
Go to your local radioshack or electronics store and purchase a cleaning disc, usually 15 or 20 bucks. Make sure you get the right one as there are diffrent cleaning discs for dvd or cd. The disc has a microfiber brush that removes dirt and debris as it spins, these can be used in all diffrent cd players, not just computers, car cd players, home. Anyway good luck L8R
Sep 17, 2007 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
