Question about AT&T Lucent MLS-12D Phone
How to program the phone
I want to program this phone for speed dial and all other functions I have available ..please help
    Champion:
  • 211 Answers
Give us more info. What functions do you need? Speed dials Feature 00 Press button to program Enter speed dial number Feature 00
Posted on Jun 15, 2009
Edit and existing speed dial
  1. Press the Function (FNC) button.
  2. Press the speed dial button you want to program.
  3. Dial the number.
  4. Press the Function (FNC) button to set the number.
  5. The message Speed Dial Set (SPD SET) displays, indicating that the speed dial button is now programmed.
NEC telephone user guide Thunderbird School of Global Management IT Help
Nov 10, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
PROGRAM SPEED DIAL FUNCTION TO MEMORY BUTTON ON NORSTAR T7316
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
Aug 04, 2017 | NorStar T7316E Corded Phone
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
I don't know how this happened, but any button I touch automatically calls a specific phone number, even if I use the intercom... It seems that the phone has been programmed to dial this number by...
Hi Evygal,
There is nothing to worry about it because this phone supports a speed dialing feature , which means that you can program the numbers in a way that just pressing them in a specific way usually for some more time than a usual press of a button will automatically enable the speed dial function and the phone will call the number that has been programmed on the digit.
A good idea to not face this problem is to quickly remove the finger off the button when you press it , because keeping it for long , just as long as one sec can enable this speed dialing feature.
Hope that helps ..:) Let me know in case you have any queries, would love to help you.
Sep 12, 2011 | Nortel Meridian M7208 Corded Phone
I am trying to set up speed dials on a samsung dcs-12b but keep getting a message saying no speed block and can't get any further
To assign a speed dial block you have to be in customer programming and go to MMC 606, once in type in either system-wide or individual extension number, please be aware that extensions can only have 5 blocks of 10 (50) speed dials, whereas the system can have 200+ depending on the size of the phone system. just to confirm 1=10. I have posted you a video explaining how to program the speed dial which is available to view on YouTube along with many others relating to the Samsung phone system. Alternatively you could visit www.abbeytelecom.com.
Nov 12, 2010 | Samsung DCS 12 Corded Phone
I have a panasonic kx-t7731...having trouble setting the speed dial...any help would be appreciated. the users guide information doesn't seem to work. thank you!
A 7731 phone will function on any one of 18 or so different Panasonic system cabinets. Now, which "user guide" are you looking at? SYSTEM speed dial is set from the first extension or the maintanance console of the phone system. PERSONAL FEATURE (speed dials on the right side of the phone) are pretty much universally programmed by PROGRAM button, 9+ number STORE.
What do your instructions say?
Carl
Sep 15, 2010 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Sep 02, 2009 | Panasonic KX-T7730 Corded Phone
Euro style 18d how to program memory keys
The Avaya website (www.avaya.com) is loaded with manuals, you just have to know where to look.. Here's one http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Page 13 tells you how to program a button (ie FEAT 00 button dial the number and press FEAT 00 again to exit). Page 16 tells you how to program personal speed dial number from the 20 bins 80-99 allotted to your phone.
Carl
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Speed dialing
There are two types of speed dial and the programming varies with the system you have.
System speed dial is programmed from the operator or manager's phone or PC and they reside in system program 001.
Personal speed dial numbers reside in my system at location 10.
You can try PROG 10 and see what the display says.
The user manual has instructrions for programming personal speed dials.
Carl
Aug 27, 2008 | Panasonic KX-T7731 Corded Phone
Programming speed dial
I have C110 and it does not have a speed dial function
Jun 10, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
AT&T Lucent MLS-12D Phone Logo
324 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
