Question about Maytag Performa PAV2200
Dryer not heating, heating coil is find
Maytag electric dryer
  • Anonymous May 24, 2008
    dryer is turning but only heating off and on.
    Genius:
  • 1,073 Answers
Check the high temp fuse on the right side of the heater housing, it has 2 white wires connected to it is about the size of a dime, it should with a meter on resistance show resistance if it is open or bad meter will not move part number is la-1053
Posted on Apr 11, 2008
The gas coils are ok by measuring them, the exhaust tube is clear but the igniter still stops half way on a maytag dryer sdg3606aww
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 25, 2011 | Maytag SDG3606A Gas Dryer
Maytag Dryer will not heat--the heating coil is not the problem, it's okay. Had new fuse put on it, but dryer still will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 18, 2010 | Maytag Dryers
Maytag mgd3500bww i changed out the ignitor and it still is not heating and the coil is not glowing either
heatman101
Oct 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have Maytag Neptune dryer. It is not heating when drying the clothes. It is about 10 years old
the most common problem if its electric is the heating element the secound most common problem is the fusable link if the fuse link to the relay has not blown then replace the heating coil
Sep 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer does not heat, but does tumble clothes and blows air., what is wrong?
Check the electric heating element. This is a long coil, looks like a long spring. That spring (coil) could be broken. If it is broken, you can just take it and twist the two halves together and put it back in. OR buy a new coil spring.. This is in the bottom of the dryer.
Sep 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Trying to check if the heater coil is bad. Is there a resistance across the coils?
Yes you should get resistance across the coil...it will vary from coil to coil....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Igniter works fine but there is no flame so therefore no heat
Replace the coils on this burner assembly. this will fix this issue you are having at this time.
The coils open and close the valves, which are responsible for gas flow. these coils are damaged.
May 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer will not heat. What part do I replace and how do I replace it (step by step)
change heating coil its simple you streach it out from where you get it from open dryer from back
Feb 18, 2009 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer will not heat up.
The most common cause for "No Heat" on GAS dryers is bad gas valve coils. Go here for more: Dryer Repair Help
Go here for Maytag Dryer Part Info: http://www.repairclinic.com/Maytag-Dryer-Parts
www.RepairClinic.com
Feb 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Washing Machines Logo
168 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
