PIXMA MP450 on Vista keeps telling me there is a paper jamb when trying to copy or print. Solution might be to clean rollers but on line manual deals only with XP not Vista for that issue...
  • jv1thompson Apr 11, 2008
    after downloading drivers I plugged MP450 into USB. it appeared that MP450 was happy until I tried to print.this was first time used.
  • 19,396 Answers
Check carefully for small fragments of paper inside the printer. A small piece of paper inside the printer may had triggered back the paper jam when you tried to print.
Chech also that there is no small object stuch near the tractors , where the printer get the paper, or inside the printer. May seem weird but I often found screws and even some coin inside printers.
Ensure carefully that all the printer doors are closed and in place.
At this point disconnect usb cable, disconnect printer from usb and power cable.
Connect cables back, starting from power cable, without connecting to pc.
If you still have the problem then you will need to service your printer.
If yo do not have the problem, eventually install the driver ensuring USB is NOT CONNECTED, this is important.
Reconnect printer only after installing the driver or when required by software.
If you still are in trouble you need to start servicing the printer.
If the problem diagnosed is paper jam (be sure) then there should be no need to use reset procedure. If you did not solve with all the above it is likely an internal fault.
If the signaled problem is different from paper jam you may be able to fix it with a reset procedure from service mode. Like this one for waste tank ink error msg.
Regards
Posted on Apr 11, 2008
  • Ginko
    Ginko Apr 11, 2008
    I forgot,
    cleaning rollers will help you if the printer is leaving ink stripes or stains on the printout, cleaning head and nozzle check is probably what you wanted to do in Vista, you will find it in the canon software , under start button, but it is difficult that you fix it with this procedure, unless is a head or cartridges related problem.
    Master:
  • 377 Answers
Try to un install first the driver that currently installed then after that install again the printer driver..
let me know what happen..
    President:
  • 1,944 Answers
Did you install the proper drivers?
  • Damen Wong
    Damen Wong Apr 11, 2008
    Cleaning the rollers is something you should try regardless of Vista or XP.
  • Damen Wong
    Damen Wong Apr 12, 2008
    So the installation went fine and only when you try to print, the printer errors?
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
Hi my mp240 is printing A4 pictures crooked. How can I fix this?
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Aug 16, 2011 | Canon PIXMA MP240 All-In-One InkJet...
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I am using Canon Pixma MP145. Paper gets jammed every time i want to print. Paper gets pulled in only from right side and it gets jammed, but printer does't show any error. I have to pull the paper...
Jul 14, 2011 | Office Equipment & Supplies
The paper is not going in straigh to be printed. its getting jammed but there is nothing in the way
Jul 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Paper jams after printing a few copys. Shows error 19
Jun 17, 2011 | Office Equipment & Supplies
Says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Feb 21, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper wont load
You can try cleaning the rubber paper feed rollers, located where the paper feed into the printer. Use a rag moist with rubbing alcohol and rub all rollers thoroughly and this should help. Good luck John
Sep 12, 2007 | Canon Pixma MP450 All-In-One InkJet...
Paper isnt loading correctly
My printer does that too, after many copies have been printed out. There is this mechanism that pushes the paper forward and another to slide one paper in... well it won't get in. I tried to add "grease" at the right side, "facing the printer", of that mechanism that made contact to the rollers which slides a paper in..  well my printer now works fine
Mar 19, 2007 | Canon Pixma MP450 All-In-One InkJet...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
