FixYa.com
Tags:
Sony KDF-E55A20 55 in. LCD Television
The lamp?
posted by JunZky_ on Apr 11, 2008
i want to know what do you mean by that "lamp" is that the CRT tube? am i correct? pls tell me?
really is have that kind of tv problem that i am going to fix.
did you mean that the tube is already deteriorating?
thnx in advance for your reply............
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 16, 2008
FixYa! (100)
F1forHelp
Rank:Guru Guru
Rating: 87%, 108 votes
This unit does not contain any CRT's. This unit uses a Optical Block Assembly to produce images on the screen. There is a lamp that is user replaceable for this model (KDF-E55A20). You can find the lamp for this model listed below.
Sony KDF-E55A20 Lamp Original Replacement
Rating Locked! (?) JunZky_ has rated this solution as FixYa!
Can you Help with these Flat Panel Televisions problems?
Spots on screen
I have circular dark spots on... Answer This...
KDF-E55A20 red light blinks 5...
If I manually turn on the set... Answer This...
Coloured vertical lines on...
Hello, I have the coloured... Answer This...
Blinking power light
When I turn on the tv the power... Answer This...
Color Hue tends toward green
I've lost the color balance on... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
