Question about Sharp 27N-S100 27" TV
27inch sharp tv comes on with blank screen,no raster. has display, but only shows through the av input. i changed the tuner and eeprom. same thing.
brd. uses 1x3253ce chroma and f0033me-h fbt. please advise.
  • 3 Answers
Changing the eeprom ic should solve your problem.
Posted on Feb 24, 2010
How to fix 14v-s100 sharp crt tv no raster only channel and volume display on screen
If there is no video signal input, this kind of fault can occur. An abnormal "Screen" voltage too can be the cause. If video processor IC or the tuner is faulty, this kind of fault can occur too. You should check all this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 25, 2014 | Sharp Televison & Video
My aftron lcd have problem with screen it opens for seconds and become black screen even i choose source like AV,TV,VGA it doesn't work what can i do pls
Do you have a device inputting into the port you are selecting ?
Try connecting the VGA port on TV to your PC's out put where the monitor connects, Boot the PC after selecting VGA as the input on the TV. Your PC's desktop should be displayed on the TV's screen
Oct 16, 2013 | Sharp R-510HW Microwave Oven
What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
Dec 06, 2011 | Televison & Video
While watching, TV made a sharp bang sound. Sound still good, channels can be changed, but no screen, no raster
While watching, TV made a sharp bang sound. Sound Problem with the Zenith Z50PX2D 50 in. HDTV Plasma Television While watching, TV made a sharp bang sound. Sound still good, channels can be changed, but no screen, now tv wont come on at all?
Sep 26, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
TV shows no input service
You may have to change / adjust the settings on your tv to use cable vs over the air antenna. When power was lost, this setting may have defaulted back to factory (Air / Antenna).
If the cable tuner is damaged, you don't need to write off the tv just yet. Try connecting a VCR to the AV / Component Video jacks, and feed the cable through the VCR (use the vcr as the tuner). Take a few more steps, but you will still be able to use the tv.
Jun 23, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Sharp Aquos LC-37BX6N - no display. On switching
Off/On The Power switch sudden 4 Straight lines appear on the screen ! what is that & why ?
Oct 05, 2009 | Sharp Televison & Video
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
Sharp 37" LCD/TV will not remain programmed with DirectV. DirectV technicians have come out to re-program the Sharp TV. They simply say over and over again that it is a Sharp problem. They keep telling me...
First of all any make or model tv will work with any directv receiver as long as it is connected properly. In my expierence Sharp TVs are compatible with all directv recievers. Is the directv remote not functionly properly with your sharp tv or do you have a black or snowy display. Your tv has to be on correct input in which the technician should of educated you on this instead of suggesting the purchase of a sony branded tv. Black or snowy display indicates the wrong input. Using the tv remote find a button labeled source or av or input and try pressing that button until you see a picture. otherwise call directv tech support at 800-347-3288 and demand that this issue is resolved immediately.
Mar 09, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp 32'' tv -no raster showing channel numbers only
since you have sound and display it's not the hivoltage. You're electron guns are not being turned on. Most likely the IC which biases the guns or the IC which contains the biasing resistors.
Jan 28, 2009 | Sharp 25R-S100 25" TV
Sharp 27N-S100 27" TV Logo
183 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
