Question about Scheu (K50-FA) Heater
Reddy kerosine space heater
The heater has sat for approx. 2 years. when last used it worked fine. when i plug it in the spark plug fires and sometimes it will ignite for a few seconds an then shut down. the spark plug also quits fireing. if i stick a small propane torch by the nozzle it will run longer. is it poosible that the fuel is to old and causing this problem.
  • 232 Answers
Bucklehead...I assume you discarded the 2 year old fuel... if not do so. Your fuel delivery problem could be caused by a number of things. 1. Incorrect air pump pressure, 2. worn or restricted nozzle, 3. deteriorated fuel line or air line, which in turn is creating the ignition problem, 4. the spark plug is bad OR you may not have a fuel delivery problem at all - just a photocell that has gone bad or has a wasp nest built betweem the eye and the flame (check this first). If the photocell can't see the flame it will shut the heater down. That's it's only job.
More troubleshooting tips
Posted on Jul 16, 2008
70 thermstat controled replaced igniter,filters,spray nosle ,hoses last year. worked fine until last week. would only run about 3 min. had to start it 3 or 4 times. then just stoped . found crack in...
Well this one is trying to detect flame, please try checking the fire eye clean the lens with windex and a terry cloth rag and try to fire it up. Make sure that this eye has an unobstructed view to the flame, not a correct thing to do but jump the eye out and see if you run longer if so replace the fire eye.
Dec 13, 2010 | Reddy R70ET Utility Heater
Ready heater sparks and theen just blows smoke
Make sure the fuel is not contaminated,and is k 1 ,if it is diesel fuel in it,and it is not made for diesel ,then that is the problem,also use a anti gel additive for gelling in the fuel,it doesn`t have to be that cool for gelling.
Jan 08, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
HAVE REDDY 55, I GET NO FIRE TO THE SPARK PLUG,
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
Won't light/stay on
It may be the spark plug (or the ignition module). On my Reddy Heater 50K BTU, there are six metal screws that join the top of torpedo tube to the bottom. Remove these,and the top of the tube casing. The spark plug should be in plain sight.
Turn the unit on and look for spark. If it's not firing, replace the plug. If it still doesn't fire, you may need to replace the ignition module (it's what is "connected to the spark plug via the fat ignition wire.")
Hope this helps,
Jan 06, 2009 | Dayton E50 Heater
I have a reddy heater model R70 that wont ignite.
I have the same problem. What is the matter with it? It seems like it will not pump fuel.
Dec 31, 2008 | Reddy Heater R70 Portable Forced Air Space...
Reddy heater won't stay on
What is the model number? Could be a number of things, depending on which technology is used on your particular 55,000 btu heater.
Nov 19, 2008 | Reddy Heater-30-55,000 BTU Variable
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Garage Heater
the kerosine heater uses a spark plug for ignition and a photocell to detect flame. at the back end of the blower motor is an air compressor. it is a vane and diaphragm compressor that supposed to put out 3.6 psi of air to the fuel nozzle. the fuel nozzle is a venturi type that creates a vacuum across the orifice to suck fuel from the tank. try this site for spare parts www dot desatech dot com. its the same place I get parts for repairing heaters.
Nov 29, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Scheu (K50-FA) Heater Logo
147 people viewed this question
Top Scheu Heating & Cooling Experts
Stuart Slabber
Level 1 Expert
Tom Chichester
Daryl Gleaton
Are you a Scheu Heating and Cooling Expert? Answer questions, earn points and help others
