Question about Sony Playstation 3 (PS3) Console
HDMI My hdmi cable is not being detected! its not a problem with the tv, and when it is detected after i restored the default settings it just shows a blank screen
  • chubbs1981 Apr 11, 2008
    I just hooked up my HDMI cable today change setting to720 press change and screen just goes blank for 30 sec then back to prev screen
You have 2 change the video bud.
Posted on Jul 27, 2008
  • blooraymaxx Jul 27, 2008
    It't video 7 on mine.
The hdmi setting doesent show on my tv
On lots if TVs if it does not detect an input signal it won't display that "channel" as an input option. I recommend check all the connections between your TV and your devices. if that doesn't appear to be the issue try unplugging all cables then reconnect everything(also unplugging devices from power). If that doesn't seem to fix it try replacing your HDMI cables if the cables went bad that could be the issue. If that still doesn't help you likely need to seek out a local TV repair service.
Jul 22, 2014 | Westinghouse Televison & Video
I cant find the hdmi icon in sounds
Hello walchell,
Welcome, and thank you for using FixYa!
To answer your question: HDMI Audio Output is part of your Digital Output package. Try turning up the Digital Output.If you are not hearing sound to your TV from your PC or DVR while connected to the HDMI cable, it is likely that you have purchased a cheaper HDMI cable that only provides video out. A high quality HDMI cable cost close to $35.00 for both outputs.
Have a great day!
Dec 01, 2011 | Computers & Internet
When i connected hdmi cable from dell lap to panasonic viera lcd tv only picture is comming no sound comming why plz advice me.
Check your graphics card control panel in the TV out setting and look for a setting to allow sound to be passed trough the HDMI cable.
You could also try changing your default sound output. 1. Right click on the speaker icon in your taskbar 2. Select 'Playback Devices' 3. In the playback tab it will show you devices that are capable of putting out sound from your laptop 4. Look for a device that will output sound from the HDMI port. 5. Click on the device then click the 'set Default' button. Sound should then be going trough the HDMI cable to your TV.
Mar 04, 2011 | Computers & Internet
Hdmi wont connect to hdmi on laptop - shows lg screen on laptop with no model number but shows no signal on tv
Hi andy838,
I see that you LG LCD HDTV is giving you a No Signal message on the Screen.
see steps Below on finding out what will show video on your LCD HDTV.
* First make sure that the HDMI cable is connected to your Laptop to the HDTV LG.
* On your TV check your remote control and look for the input or Source Button, this will help you set your TV for the HDMI connection.
* Once set, turn your Laptop on and see if the HDTV will provide Video from the Laptop to your HDTV using HDMI.
* I believe that works right, now we have video still we need to set the Audio to work from you Laptop using HDMI to your HDTV.
* On your Laptop lower right side look for your speaker icon, right click on the speaker icon then select Playback Devices.
* Once you've selected Playback Devices you will see a window showing you a list of devices and the first one on the list will be you HDMI connection right click on it and select set as default device this will make your audio work on your HDMI to your TV.
* Once audio to HDMI is set and you want to go back to your Laptop just set the speakers as the default device this will set your speakers have the Audio working again on the Laptop.
I hope that this will help you regarding your concern.
Have a nice day,
mvincentc
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
Hdmi doesnt show picture
a few things to check. 1) does the TV tune to the appropriate HDMI port? If not then it isn't detecting a signal from the PS3. In that case you may not have HDMI output turned on. If you can reconnect the A/V cables then go to the system menu to display and set the output correctly. Start with 720p and work your way up to make sure you don't set it to a resolution that your TV can't handle. If you don' have the A/V cables then boot into safe mode and reset to default. This will reset the PS3 to out of the box settings (no data lost).
May 04, 2010 | Sony Playstation 3 (PS3) Console
Have hooked up HP Pavivillion PC with HDMI cable; get no audio, picture is fine. How do I get the audio to the TV??The TV is a new Insignia NS-L37Q-10A.
Plug in the HDMI to the TV and set the TV to HDMI input. Go to the Vista Contol panel on the PC, to Hardware & Sounds, then Sound.
The control panel will show the computer speakers as the default hardware. Highlight the HDMI icon, click the Default button! That's it: obvious when I realized "default" was not "return to default settings", but setting the default device. Duh... always simple once you see it.
Thanks, Rick Russell
Nov 13, 2009 | Insignia LCDTV26 26 in. Television
No sound on tv when laptop connected via hdmi
if you are running windows xp or linus i may not be able to help altought the problem might be solved in almoust the same way. For windows vista right click on the volume icon in the system tray icons and choose playback devices select HDMI output ( for 5920G is "Realtek HDMI Output" ) then press the "Set Default" button. The other way around is to go in the Control Pannel in the "Hardware and sound" cthegory and select sount than seth the default output to Realtek HDMI Output in the "Control Pannel Home" view, or in Classic view click/doubble click on "Sound" icon ( a speaker ) and do the same. In windows XP there is a similar approach. In linux go to System ->> Administration ->> Soundcard Detection and you should find a setting equivalent to the one in Windows
May 29, 2009 | Acer Aspire 5920 Notebook PC
Playstation won't show up on tv at all
Try this first then get bak to me Settings>System Settings>Restore Default Settings. after you try this. This should be your problem connect the av cables to the PS3 then while the system is off by the switch in the back put your finger on the front power button hold it there then while still holding it turn on the switch in the back still hold the frosnt and wait for the second beep then let go then set up you HDMI just plug in the cable and follow the steps. If all Fail do the above answer if fail again message bacck.
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Hdmi channel not showing PS3 only sound
might be problem with PS3 rather than telly. Try another HDMI cable in case something wrong with yours. You can try and reset PS3 video output by holding power button down (when in standby mode) until it beeps, them use original cable and see if that shows up on your TV. If so reconnect HDMI cable Ps3 will detect it and change settings back to HDMI then see if the TV picks it up.
Dec 11, 2008 | Televison & Video
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
