Question about HP Officejet 4110 All-In-One InkJet Printer
Fax Having an issue getting the fax to work, its hooked up to a working phone line and will not connect and has my old number still loaded
    President:
  • HP Master
  • 990 Answers
1, make sure the phone jack on the wall is activity
2hook up wall jack with your fax machine
3, if still don't work change a cable
4, if still don't work change another phone jack
Posted on Dec 07, 2008
    Sergeant:
  • 352 Answers
Hi MikaeIM, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Posted on Oct 14, 2008
I have a Epson all in one printer, scanner, fax etc. and when I try to send a fax I get busy report.
Try to send a test fax to HP's fax-back line:
1-888-HP FAX ME
You can send a blank page and if they receive it they'll send you a fax back confirming it.
If you can send to HP then whoever you tried to fax to earlier is having an issue or the number you have is wrong.
If you cannot send to HP then there's an issue with your line/machine.
You would then start troubleshooting by hooking up a phone to that jack you have your Epson plugged into and seeing if you get a dial tone.
Jun 01, 2011 | Office Equipment & Supplies
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
ERROR T82 BIZHUBC280 IMPOSSIBLE TO SEND OR RECEIVE FAX
Check your fax line connection is the FAX line plugged into the Line jack on the copier and NOT THE TELE connector. Must be Line. Take a old phone like a old princess phone and hook it up to the wall get a good dial tone call some one any noise? Have some one call the fax number OK if hooked to the copier get the tradition noise of a fax line, Check the fax line itself use only one with two wires not four, black and yellow only no red and green. Also put on one of the EMI devices on the cable going into the copier cut down on electrical noise. Line can not be digital must be all analog (POT) Plain Old Telephone, have your phone provider check the line.
Oct 18, 2010 | Minolta Office Equipment & Supplies
I have a hp officejet all-in-one and I can't get the fax function to work. I have comcast digital voice with a rca modem. The fax machine dials and the line goes dead. If I call the fax number on the...
Since you have a DSL ( Digital Subscribers Line ), the HP Fax printer works on Analogue Signals.
To make the GP Printer work on Digital line, First step you can do is to Reduce the Fax Speed from Fast/Medium to SLOW.
To Do so, Click on Setup button on printer front panel - Choose Fax Settings - Choose Fax Speed - Set it to Slow and try to fax
If this does not work, you will have to connect a DSL Filter ( this is a 2 way port - 1 port for Digital line and another for Analogue )
You will have to connect this Filter to DSL Phone line - in the IN port and from the Analugoue Port - Connect Phone cable to Printer Line 1 EXTN Port at back of Printer
Jul 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp office jet 5610 all in one printer--- am I able to fax without hooking up to a computer if yes how- thanks
All the HP office all-in-ones fax without computer hookup, simply place the fax on the load tray face up until you see the window state that the original is loaded. Then on the number pad dial the fax number you want to connect to, once that is done...press the black fax button and the machine will dial the number, once a connection is made the fax will feed itself through and complete. The only connection needed is an outgoing phone line. Just make sure that the phone line is in the right socket on the back. You will see icons by the sockets, the one with the phone icon is for a line to go to a phone headset....this is not the socket for the main phone line, ise the other one that says "line".
Jun 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Machine shows "phone off hook"
Hi there
check where your phone cale goes into the machine you will proberbly find two sockets one marked phone and one marked line the phone line needs to go into the one marked line and a phone handset in the one marked phone if this is correct try ringing yor line that the fax is plugged into see if you get a ring or engaged tone if you are getting engaged unplug the fax and try again if this now works the chance is that the modem board in your fax has failed and will require replaceing
Regards AL "alstech"
May 18, 2009 | HP Officejet 5510 All-In-One Thermal...
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Fax network not working
Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
Jul 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Can't receive fax - fax rings 2ce then just stops / says phone off hook
Hi Iryan,
Instead of switch box, a more dependable option is to get a distinctive ring. Your local phone company offers this option. What's neat about is you get a seperate fax number. Its like having a dedicated fax line without adding extra lines to your service. I think the monthly fee is around 3 dollars a month for this feature, but, believe me its well worth it.
anaanymous
Jul 15, 2008 | HP Officejet 4110 All-In-One InkJet...
Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Jul 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 4110 All-In-One InkJet Printer Logo
48 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
