Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
Ide drive showing up as ide 3
I have one IDE connected to this system there is only one IDE physical connecter, but when my computer boots the harddrive come up as ide 3 instead of primary and will not boot??
Thanks
  • 53 Answers
Hi ,
Set the jumper for Primary IDE at the end of data cable the first two pins (not side by side,opp ) short
It is also wrritten on the HDD.
pl try it
Was this soultion useful?show ur appericiation by rating it
Posted on Apr 12, 2008
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
Feb 19, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
How can i change the real time clock....
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart.
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope it helps
May 05, 2012 | Dell 038HRF GX150 PENTIUM-III SYSTEM BOARD
GA-EP41-UD3L problem with SCSI/IDE
Sounds like the motherboard bios is only capable of booting from drives connected to the motherboard's ide connector and not additional / or external ide connectors. Looks like you would have to have 1 HDD and the CDRom Drive on the built in ide connector and the other hard drive on the extra ide connector you added. Although that would probably stop the other HDD from booting. Have you thought about putting both operating systems on the same drive. I do it all the time.
Feb 11, 2012 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Gigabyte ga-8i915p duo motherboard ide problems
RAID stands for Redundant Array of Inexpensive Disks.
The RAID system uses multiple number of hard disks to give a fast and fault tolerant storage using several disk controllers.
There are various levels of RAID, for info on RAIDs check out
http://en.wikipedia.org/wiki/Standard_RAID_levels
Apr 03, 2009 | Asrock P4VM8 Motherboard
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Ide problem
just set the sata as first boot hard drive in your bios then connect the other drive :- )
Nov 11, 2007 | ASUS P5LD2 Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
53 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
