Question about Fujitsu LifeBookS6120 Notebook
Laptop crashed While using my laptop, it just crashed and I can't even sign in.
  • marzelyoung Oct 16, 2008
    just a grey screen, nothing else, tried repeatedly pressing f8 ,nothing
Just a grey screen, this lap-top is my nephews ,who is handicapped and has asked me if i could help him , anything to help would be gratefull. the lap-top just lights up,no sound or start-up page,have tried repeatedly pressing f8 but nothing happened,
Posted on Oct 16, 2008
  • 472 Answers
Try this:
  1. Turn on the laptop
  2. Wait for the first page to go blank.
  3. Start to press the F8 key repeadly
  4. You should get a Windows Start" page pop up that gives options on how you want to start Windows.
  5. If you see the Windows Logo (the screen you normally see when Windows starts) screen then just restart the laptop again.
  6. Choose "Last known Good Configuration" and press Enter.
If that fails then please post back and we can try some other things.
Posted on Apr 11, 2008
Won't boot linux cd
Try changing the boot order to HDD.
Mar 07, 2013 | Gateway Computers & Internet
I just installed Alice Madness Returns on my new laptop.
Most key codes can only be used in one computer at a time, it seems that the game program thinks the key is in use in another computer which essentially it is, you can try contacting the company you got the game from and have the other laptop which crashed "disconnected" from the key code, you can also try to activate the game on a friends internet connection at their house this way the game won't recognise the IP address.
Sep 18, 2017 | Electronic Arts Alice: Madness Returns
MY DELL E 1505 IS OVER HEATING AND GETS HANG
Due to their small size and lack of ventilation, laptops tend to overheat more than desktop computers. A noisy cooling fan that runs continuously is one sign that your laptop is overheating. Laptop overheating can also cause a loss of performance, system crashes, and even permanent damage to components. The goal is to make sure your laptop has proper ventilation and is kept as cool as possible.
1.Always use your laptop on a tray, desktop, or other cool surface. If you use it on your lap, make sure clothes, upholstery or bedding are not blocking the case vents. Blocked vents are the number one cause of laptop overheating.
2.Use an aerosol air duster, or can of compressed air, to blow dust from the air intake vents. Air intake vents are a set of slots on the side or bottom of the case that allow cool air to flow into the laptop.
3.Clean the cooling fan exhaust system. The cooling or CPU fan is located on the side or back of the case. A clogged CPU fan vent keeps hot air trapped inside the case. Use an aerosol air duster to loosen the debris, then use a vacuum cleaner with crevice tool to vacuum out the dust and dirt.
4.Use a commercial laptop cooler. A laptop cooler pad is an external USB powered fan that serves as a base for your laptop. If your laptop generates a lot of heat, even with a clean cooling system, a laptop cooler will extend the life of your laptop.
5.Adjust your BIOS settings. Most laptops have features built into the system BIOS that allow fan speed, CPU temperature alarms, and other settings to be adjusted. Read your owner's manual to learn how to enter the BIOS and change the settings for your particular laptop model.
Sep 26, 2011 | Dell Inspiron E1505 Notebook
Every time i turn on the computer it seems to crash. Sometimes it takes an hour before it crashes and sometimes i don't even get to login before it crashes. My definition of crash would be where the...
There are usually many possible problems.
Sounds like you have low resources.
Not enough RAM
Or your processor is having problems.
Depending on your OS, and or programs you are using.
Freezing is a sign of a need to upgrade.
Your pc is likely slow.
If this is not the issue, then you should provide more info.
Mar 16, 2010 | HP Compaq Presario SR5350F Desktop PC...
It won't do ANYTHING. I got a nasty virus - and it won't even allow virus/spyware scans to open, much less run. Now, I can't even sign on. Even in safe mode, I can't run the scans. Am I going to have...
Let's not go into the details. If you have sensitive data, you should be more concerned about getting that backed up.
My best advice to you if you're a novice is:
Take the computer to a computer repair shop. Ask them to backup your data. OR you can do it yourself if you have Windows XP CD. You'll probably have to format the whole thing anyway.
Good Luck!
Feb 19, 2010 | ASUS Eee PC 900 Notebook
Hp laptop keeps crashing
May its your hard disk wish have a problem. Try to install your OS on an external hard disk or change the internal hard disk. See what happen. if it show blue screen it may be an hardware error.
Feb 15, 2010 | HP G60-120US Laptop
My inspron 6000D makes a buzzing noise when its turn on. Is this a sign that the hard drive is about to crash?
Could be a sign of impending disk crash, or, it could be the fan. One way to check is open the notebook to a 90 degree angle, and CAREFULLY rest the computer on one side, then use a sewing needle or tooth pick to stop the cooling fan, momentarily (about 2 seconds or so). if the noise subsides, then the fan is the culprit. If not, then back up your data, and get ready to replace your hard drive
Aug 24, 2009 | Dell Inspiron 6000 Notebook
My HP laptop (1 gig memory) crashes when using Photoshop
crashes, as in locks up? What kind of video memory or card you have? And, how do you have it optimized(faster performance, most likely)? This takes a bit of 'tweaking' to get just right.
got backup for your HP?
Feb 13, 2008 | HP Pavilion zd7020US Notebook
When I plug in RBG cable to laptop, it crashes
i need for a msr206 24VDC /-10%, 2.0A Max., external power adapter attached
Dec 17, 2007 | Focus Enhancement i-Tview Gold (444-6201)
Fujitsu LifeBookS6120 Notebook Logo
280 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
