Question about Kenmore 22612 Bagged Canister Vacuum
Will not start
Works sometime. Thought it was old HEPA filter. Replaced it and it ran for a few minutes and stopped again.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=109422&thid=505790
Will not start
Posted by jlouis on Apr 11, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22612 Bagged Canister Vacuum. It sound sot be that it could be your electrical hose be have a short in it or your carbon brushes needs cleaning or replacement or the worst problem is that it could be your motor, fields or armature. Most motors can be rebuilt but I would check the simpler things 1st B4 you try to rebuilt or replace the motor.
I am not sure if Sears / Kenmore can download the owner’s manual from the website but I would suggest that you call the Sears / Kenmore Factory to have them send out a copy of the owners manual so that you can do it yourself or if that is not the way you want to do it contact your local vac dealer and they can help or call the factory for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
I was in the middle of vacuuming and all of a sudden the vacuum just stopped working. I looked, thought the bag was full so I changed it out and nothing it will not turn back on again.
If the bag was really full it could have restricted the airflow and caused it to get too hot and shut off. If it does not have a mechanical reset button it will come back on after it cools down. The filters may need replaced too.
Feb 20, 2017 | Kenmore Vacuums
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
Subject: Eureka Tru Hepa Wirlwind Amps Model 4383. Working fine then just stopped. Later worked fine again? What is/was the problem? Does it need a new filter?? also has the # 0108017529 on machine
I'm not sure all machines are the same, but many have thermal overloads on the motor that can only be reset upon cooling, so wait 30 minutes and try again.
Secondly, my vac has 3 filters, one in the dust tray that you empty, one under where that dust collector installs and the HEPA filter on the back.
Ensure that all three are cleaned.
Gary
Feb 12, 2011 | Eureka 7619AT Vacuum
It stopped working while vacuuming. Still getting power, compressor still working but not sucking.
I'm an owner of an LG LuV200R vacuum cleaner. After years of use it started having an overheating issue where the suction motor stopped after only a few minutes use. The brush motor and compressor motor still worked. After cooling down with power off for at least a few minutes suction motor worked again but quickly shut down. Here's how I fixed mine:
First make sure to clean all 3 filters and let dry for 24 hours if cleaned with water (recommend, but compressed air works good too). A clogged HEPA filter could cause overheating. Check all air passages and hoses for blockages. I've always maintained/cleaned my machine so I had to go a little deeper...
On the control board there is a semiconductor which screws to a right angle aluminum heatsink. See attached picture. My screw was slightly loose; loose enough for there to be a tiny gap between the metals so little heat was dissipated from the semiconductor. My infrared thermometer showed 260°F while running. I tightened the screw and running temp went down to 160°F. Once reassembled the vacuum has yet to overheat and shut down. It's a great vacuum so I'm glad it's working again.
To access the control board you need to remove the front facing plastic motor housing located below where the cord is stored. ALWAYS unplug unit before opening. 2 screws face the rear of unit, (now tilt top of vacuum down all the way) 2 screws face the front at the bottom, and 2 more right above HEPA filter (remove HEPA filter). There is a nut behind culprit screw so you may need to remove the control board attached with 2 screws. I recommend using compressed air to clean off control board if dusty, and check for cut/burnt wires. I had a darkened wire which I guided away from control board at reassembly.
A dab of locktite wouldn't be a bad idea on the loose screw/nut. Hope this helps others.
Jan 29, 2011 | LG Electronics Kompressor Pet Care Upright...
BB1100BdD stops after a few minutes operation. After an hr or so will run again for a few minutes
The motor is overheating and control features cause it to shut off to prevent burning it out. First check the bag. If it is full, remove and replace with a new one. A full bag can cause the motor to work harder, and thereby overheat. Next check the filters. A dusty filter will keep air from cooling the motor and again cause overheating. The HEPA filter needs to be checked also. Most filters can be dusted off. Some can be washed, air-dried, and replaced.Others will need to be removed and replaced. Your owner's manual should tell you how to clean filters. I hope this helps. If it solves your problem, please let Fixya know and post a rating for my solution.
Nov 19, 2010 | Oreck BB1100DB / BB1100DC Housekeeper...
Brush works intermittedly - I've looked at the common solutions listed but none seem to work...shaking it & reseating the canister will get it working again sometimes but obviously that doesn't seem to...
I just had the same problem. I would turn on the vac, and it worked fine. When I turned on the brush it would work for a few seconds then shut off. Through troubleshooting I found out it had nothing to do with a bad power connection. By chance I took off the side HEPA filter to see how it looked. I realized that I have never changed it and that it was filthy. I removed it and turned on the vac, then the brush. It took a few tried, but the brush motor got back to full strength. I reassembled everything and it works fine now. It seems that the clogged filter was causing the brush motor to shut off. I'm running my vac w/o the HEPA filter while i wait for a new one to ship. Hope its the same prob for you!
Aug 30, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Keeps shutting off
You cant clean the HEPA filter.. only the blue washable pre filter.
Sounds like the motor is dead or atleast on its way out.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Motor stops running after a few minutes
One thing you could have a bad motor control, part #05408630, mounted by the motor, the other could be a bad variable speed control, part #05412914, it is on top near the back.
Dec 08, 2007 | Miele s558 Silver Moon Vacuum
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Kenmore 22612 Bagged Canister Vacuum Logo
157 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
