Question about Dell 2000FP 20.1" LCD Monitor
Dell 20 Hi my dell lcd monitor won't gon after i saw a smoke . I open it and don't see anythink burnd bye Dave
    Sergeant:
  • 209 Answers
Dear Tirat
Hello Dave, well unfortunately your problem here is not going to be all that easy to resolve as components that burn out are not always visable to the naked eye. However, there are logical methods of approach that you can undertake to possibly find out and recify what has caused this fault. Let us start by looking at the supply signal (DC current) that is received into the monitor unit. By using instruments such as multimeters and oscilloscopes on components at power supply source, you may be able to work out ifany of the crital parts have broken down. For instance, Capacitors are rated on the farad scale or microfarad in the case of small DC circuits carrying low voltage (uF). So it may be worth checking service sheets in order to find out what the read ratings and load ratings are, then compare them to the read ratings you have.....If they dont match, then you have found the fault at supply source, and the same methods can be applied throughout the entire DC circuit. It is time consuming, but it will make for a good project, and if you find the fault, then components are fairly cheap to acquire from either partstore.com or maplin electronics.
There is one other possible reason for the smoke and no burning marks, an that is tha you have only concentrated on the main PCB, so i recommend looking at the back-light and LCD Unit itself. Both of these components carry large enough voltages for smoke to be produced, and the burn/ scortch marks are not so evident unless you ae specifically looking for them here. What you will be ooking for, is a small strip-ligh or florescent type tube with either smooth soft white or black wires attached to it, the insulation of this wire is smoother and largely differs from that of other wiring within the unit, so this component will stand out to you.....Once you find the tubing, if it has been burnt, or had a fire the tubing will have been broken, and you will need to replace this and first find out what caused the fault to happen in the first place....WARNING....LCD SREENS AND CERAIN COMPONENTS CARRY HIGH CURRENT AND VOLTAGES THAT MAY BE HARMFUL IF YOU COME INTO CONTACT WITH THEM, SO BE SURE TO POWER DOWN, AND PROPERLY DISCHARGE THE UNIT FOR 24HRS MINIMUM BEFORE UNDERTAKING ANY DIRECT CONTACT WITH COMPONENTS. IF IN DOUBT, CONTACT AN APPROVED SERVICE ENGINEER.
So as said, your best bet is a logical systematic approach, deal wth the supply source first, then trace back to the display in order to find your fault. The other main reason for this is that to replace a power supply and a few components at supply source within the monitor is cheaper than shelling out for a new screen and backlight. So always start with the cheapest first.
Lastly, your other indicator that you may have either blown LCD or backlight is evident if the power LED (green light on screen) is on, but you get no picture, however this can vary from model to model, as the internal circuitry is arranged differently on other monitors, but its still well worth a look.
I hope that this has proved useful for you, and if you do need further assistance, then please do not hesitate to mail me back as so i can assist you further, i will b here pretty much all the time, so just feel free to ask me or comment, nd i will endeavour to respond
yours sincerely
oz
Posted on Apr 11, 2008
Smoke came out from the back after I tried to replace LCD monitor in my Dell laptop E6430s
be sure you had installed a compatible LCD on your system. take out all the connection of the lcd and try to figure out where the smoke came from, in might be from the inverter or from the supply.
thanks
Apr 01, 2014 | Dell Latitude E6400 Notebook
Monitor has switched view through 90 degrees.How do I change it back?
HI HOWR YOU
IWHAT FRINEDS
MY NAME IS BADER
AND WHAT YOU NAME
BYE
Apr 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My Dell Inspiron 640m laptop LCD gons blank after it is sipped down. Processor working sound is hearing & lights are glowing, But only LCD is not working. Any solution pls....
turn off comp then press "D" and power button to perform built in self test. connect external monitor hten press "Fn" and "F8" to toggle video from LCD to external monitor and vice versa.
Feb 23, 2010 | Dell Inspiron 640m Notebook
The on and off button won pop back out so that i can push it in to turn the monitor off and on.
Call dell with the 20 digit serial no at the back,if it is in warranty you will get a replacement monitor for this issue i had the same problem mine was replaced
Normally Monitor has 3 year warranty for parts
Dec 30, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
The monitor works but is very dark and cannot see much at all. I can just tell that it works cause i can faintly see the background
soccerstu546, The video information is being displayed.... but you just don't have any cold-cathode-fluorescent-tubes" emitting enough WHITE-LIGHT to brighten up the image and or text. If you have never used a soldering iron and solder and don't know an electrolytic cap from a mylar cap then you should look into swapping out your monitor if DELL has a cash+monitor swapout program going. They will return to you a refurbished unit that should last at least 1-2years. You should read up on the top 2 reasons LCD monitor screens GO BLACK!!! I almost guarantee you will be in the one for FAILED SMPS/INVERTER SUPPLY. You may also need to search or visit www.badcaps.net and other sites that deal with failed lcd displays. you could even try right here on fixya to get it REFURBISHED! Wow, If you saw some 8-12min vid clips on youtube you might even want to do your own disassembly of your LCD Monitior just so you can use you digital still camera to document any SWOLLEN ELECTROLYTIC FILTER CAPACITORS that are inside the monitor. Also try moving and connecting your monitor to a different PC. If same result---Then monitor is BAD. Well--anyhow bye for now. louie12fix on fixya or lmistyrel @aol.com
Sep 26, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
How to open the Dell 1707FPV flat monitor? Thanks
lanhqua, If you visit youtube you can see video clips (8-12min) of some LCD monitors being disassembled for servicing/repair.... May I ask what you will do if u get inside your DELL 1707FPV???? Do you know what to look for? Bye for now. louie12fix on fixya or lmistyrel @ aol.com
Sep 25, 2009 | Dell 1707FPv Monitor
My dell went off after few seconds, the power light is still on. I checked inside and saw the transformer EPC-19 sparking. on the side of epc-19 there is another number : 0101NH25G. Please tell me where or...
Only place I can find them is to go to ebay and type epc-19 in the search bar. They have some in stock for $20
Also many dell monitors have a 3 year warranty standard...it's worth calling 866-876-3355 and ask them if the monitor is indeed under warranty or not.
Jul 15, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell e171fp + turn off after a second
hi, are you able to browse thru the LCD menu, there must be some settings for power management.. let me know?
bye
Dec 15, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Monitor
ferozkhan, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually an economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Apr 25, 2007 | IBM E74 17" CRT Monitor
Dell 2000FP 20.1" LCD Monitor Logo
120 people viewed this question
Alun Cox
