Question about Olevia LT37HVS 37 in. LCD HDTV
Loud static blasts
Periodically, and for no apparent reason, my 37" Olevia HDTV will emit a LOUD buzz, or static blast (the only way I can describe it). If I am away from the room, I'll have to run back and turn the set off, then turn it back on to stop it. After that, it will usually perform well, however we can't leave the house with the TV on for fear that this frighteningly loud noise may result in an explosion or something worse. It can actually be quite unsettling
  • 1 more comment
  • stid Apr 15, 2008
    Since I have no external speakers connected to the set, I'm assuming, possibly incorrectly, that the emanate from the internak speakers. When I turn the TV off and immediately turn it back on, it works fine until I finally turn it off for the evening.
  • stid Apr 15, 2008
    I have no idea what a "LOT" unit is.
  • stid Apr 15, 2008
    I am assuming that since the volume of the sound is grossly disproportionate to the prevailing speaker volume at the time, that maybe it isn't being broadcast over the internal speakers.
  • 796 Answers
The LOT is not working properly...
have you checked that unit??
Posted on Apr 11, 2008
    New Friend:
My FStar TV does the same thing. Functions fine for a few hours and then blasts out a very loud medium to high pitch squeal, sometimes as loud as an air-horn. Happens on all inputs and the sound is far louder than the loudest volume I thought my TV speakers were capable of generating. It lasts about 7 seconds. I also have 7 second periods where there's no volume at all. I think it's a bad power supply or the electrolytic capacitor. As an electrolytic capacitor ages, its capacitance usually decreases and its equivalent series resistance (ESR) usually increases. The capacitance may abnormally degrade to as low as 4% of the original value, as opposed to an expected 50% capacity degradation over the normal life span of the component. When this happens, the capacitors no longer adequately serve their purpose of filtering the direct current voltages on the motherboard, and a result of this failure is an increase in the ripple voltage that the capacitor is supposed to filter out. This results in a system instability.
Posted on Aug 12, 2013
  • 4,889 Answers
Yes can you please verify whether its coming from the speakers or not?
Posted on Apr 15, 2008
  • 4,234 Answers
Static noise can come from a number of places. The key is to try and find a pattern to when it occurs. Does it only happen after the unit has been on for a while? Is the set still under warranty? DO NOT open it up if the warranty is still valid. Since the problem seems to come and go, it suggests either a heat or connection problem. Given the signal levels inside the set, connection problems can occur and result in many types of problems. Try to post the following info and we should be able to help further:
1) Look for a pattern of when it occurs.
2) Does the set work for a while even right after a power cycle to clear the initial problem or does it occur again right away?
Thanks,
Dan
  • ABRsvcs Apr 15, 2008
    Thanks for the update. The next step is to determine whether or not the sound is coming from the speakers. I suspect that it is. Bad coupling capacitors in the audio path can cause this. This is important: is the set under warranty? If so, return it for warranty repair. If not, we'll need to start looking at hte audio path. Are you comfortable working inside the set? Are tyou familiar with electronics?
    Dan
    Brigadier General:
  • 3,614 Answers
A sound from your speaker or it was coming from the unit(inside)..?
Why is My cimbali 21 s junior is making a loud noise when turn on
The La Cimbali Junior is a 1 group professional espresso machine. Most are located in restaurants that want to serve a cup or two for customers. You will find few homes with this level of machine. Especially with the proliferation of "Mini Super-Automatics" now offered where the whole been is ground, measured, compacted, and served with exacting amount and some top off with frothed milk!
The JR has several items that will normally buzz or whine when in operation. There are also defined "Clicks" of the group valve when a shot is pulled. I will go through the list of likely components that make loud noises when about to fail.
*** The following is for information only! Call your vendor for service as there are dangerous voltages, high pressure, and scalding stem present in these types of professional machines. ***
* All JR's come with a water pump. Two types; Vibration and Rotary. The vibration makes a buzzing sound (50/60 Hz) which will get loud if there is a blockage. The rotary pump with it's accompanying large motor will also "Clack" if no water is flowing through. Stop immediately as both sounds are an indication of a straining pump. If it suddenly goes quiet then the pump is damaged or hopefully the fuse blew. Call for service.
* The group valve will usually buzz when pulling a shot. But if it's louder than normal then there is a problem with the valve (clogged) or coil (shorted). Call for service.
* If there are loud blasts of steam and a quiet period with another blast in about 10 mins. Then the boiler is over heating (runaway steam). Unplug and call for service.
* If there is constant steam blast from the top, even if it's turned off (But NOT unplugged) the element is shorted to water. Unplug immediately and call for service.
* Popping sounds are normal at start up as the metal boiler expands during initial heating. But not after 10 mins of heating. Especially if you see water/steam coming from parts of the machine you don't expect. Unplug. Call for service.
* Power/Heater contactor will buzz if coil is damaged or contacts burnt. Call for service.
* Final; I do not recommend opening the machine yourself as once you hear a loud noise it's usually too late and the damage is done.
* Parts that needs check/replacement; Vibration or rotary pump, motor, group valve, safety valve, vacuum valve, thermostat/pressure-stat, element, boiler and element gasket, contactor.
Aloha, ukeboy57
Aug 26, 2014 | La Cimbali Junior Casa DT1 Espresso...
Cannot get speakers to blast my music
if you blast music to loud you blew out the speaker and you hear a little music ... you blew it out you need to buy a new one
Mar 13, 2014 | iLive Audio Players & Recorders
Car radio is blasting loud when first turned on.
That is imposible buddy.Before you get out of the car turn it down.Then you should not get a blast when. you hit the power button to turn it on.
Oct 22, 2012 | Phase Linear Jensen PCD161A In Dash CD...
Bose Wave Radio, Model AWR1-1W When turned on radio emits a loud buzz and no other sound. Pushing tuning, volume, and aux buttons has no effect. Is this fixable? If so, how?
Loud buzz is usually caused by static and radio interference in radios. If none of this is affecting you unit presently there there is a probability that some cables which aid the fm antenna in receiving stations this could act as static which brings about the buzz on the unit. Either way it is caused by interference on the fm receiver end and all you have to do is get that serviced and the problem is solved.
Hope this solution has been helpful?
Dec 30, 2010 | Bose Wave Radio
Loud buzzing sound began on start up
It could be several things but the most likely are: Something is spinning around with the motor shaft. Unplug the motor and "blast" water through the vent holes to clear debris. Let it dry completely before returning to service. Something could be caught in the impeller. Remove the front end and check. Squeals, loud hums, heat and vibration are indications of bad bearings.
Apr 17, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do I fix bad static? Dell W3706MC 37 in. HDTV LCD has been fine and suddenly the sound has loud static on all sources. Is this a sound circuit failure?
Yes,loud static usually comes from bad isolation of sound signal path so it's probably a frayed cable or a loose jack. Or if you're unlucky some parts inside have failed.
Oct 26, 2009 | Dell W3706MC 37 in. LCD HDTV
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
Olevia 37 turning off for no particular reason
I suspect that the main power supply is trying to self-destruct; what you describe could be the switching power supply struggling to stay up and running. It isn't the cable company's problem.
FYI: Olevia has declared bankruptcy so you may not be able to get any help from them.
Nov 17, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Projection 52" lcd
so use the warranty as is less than a yr old let them fix it....
Aug 09, 2007 | Hitachi 60V500 60" Rear Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
458 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
