Question about 3M SV-497AJM Vacuum
Vac specs Is this product acceptibal for nuclear grade Hazmat?
    Problem Solver:
  • 5 Answers
I would not think so since it has no micro filter system. It contains a cartridge that was designed for Copy machine toner.
Posted on Dec 14, 2008
I need a manual for a Sop-vac 1.5 gallon.
Have a look at this page and if it matches your product, you can click "user manual" on the right hand side to download a PDF version of the manual.
Shop Vac 1 5 Gallon 2 0 Peak HP All Around EZ Wet Dry Vac
Sep 19, 2017 | Vacuums
Need charging station for Shark Cyclonic 12 volt cordless power-vac
Buy a replacement charger from the Shark Cyclonic dealer. It is important that the specs match the battery, one or two volts higher can shorten the battery life by quite a large amount.
Aug 03, 2015 | Shark Vacuums
How do you replace the switch on a shop vac 2.0 quiet series
The switch should be connected to the power cord just use a multimeter to work out where the wires go , do you have a pic of the switch ?
Jun 25, 2014 | Shop-Vac Products 5-gallon 2 0-peak Hp Wet...
Acorns in top of Shop-vac
Leave it outside for the squirrels and mice to remove the acorns. It is unlikely the acorns passed through the filter and fans. Can you see them to know they are in the top of the vac?
Jan 26, 2014 | Shop-Vac Products 850-02-10 - 850-Series...
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
I am trying to find a new switch for my Rival Titan Model T 771 Electric Heater.
http://rocker-switches.carlingtech.com/single-pole-switch__42.asp
I believe this is it
10A 250 VAC
15A 125 VAC
3/4 H.P. 125 250 VAC
They have a list of retailers who sell their products.
Dec 09, 2010 | Vacuums
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
I was given an Electrolux vacuum model 1401-B. I would like to download a manual for it. Do you have one? Thanks, Carolyn
Carolyn, The 1401B is one of a family of US built LUX models , now sold by AERUS Electrolux. It shares common info with the MARQUISE, Super J , Olympia and 1205, etc so if you come across a used manual for any of them you will be in good shape.
Try an AERUS Electrolux dealer but the manual may be out of print.Also try a local vac shop
Quick rundown, :
Set the dial at front between medium and fine and don`t adjust, this is the bag fill control, NOT a suction control.
Only use genuine 4 ply filter bags from a pro vac shop, not grocery store grade as this is a vac which filters thru its bag.
Hang the hose for longer life, obstructions can be blown out thru plugging the hose in the blower port under the slide door behind the handle.
Inspect the power head for hair and thread and remove any visible.
When you wheels squeak while vacuming spray the axle shaft behind the neck with a drop of WD 40.
If you feel air venting thru the hose behind the handle or if it is crushed and kinked there or at the vac replace the hose for better suction. The weight of this vac weras out hoses. When the castor below the body cracks and it will, match it with a small SHEPARD castre at the hardware store.
If your rewind is sluggish, pour a tablespoon of talc or baby powder in a tissue and run it up and down the lenght of the vac cord end to end. Then drop the tissue into the vac bag fro fresh scent.....
Enjoy the vac, this one is a great one 30 year plus life span, parts are still available keep it in good repair
Oct 10, 2009 | Vacuums
3M SV-497AJM Vacuum Logo
Top 3M Vacuums Experts
JoeVacs
Are you a 3M Vacuum Expert? Answer questions, earn points and help others
