Quicktax wont install becuase of incorrect dispaly resultion, how do i chand this to fit
    Genius:
  • 1,027 Answers
  1. right click with mouse on any open area of desk top
  2. left click on properties
  3. left click on settings
  4. adjust screen resolution
  5. click apply
  6. it will the test new resolution for 15 seconds, if adjusted correctly click OK
Posted on Apr 11, 2008
My alternator for my 2004 Mazda Tribute Wont Charge and My Dash Wont work at all.
it is possible that the after market radio is the problem
unless it is installed correctly it may be draining power from the dash wiring or using that schematics as an earth incorrectly
fitting after market radios in modern cars is not a diy effort as the original radios are now attached to the ECM of the car and fitting the radio incorrectly will cause problems
Jun 30, 2015 | 2004 Mazda Tribute 3.0
How to fit timing belt to a ford transit connect 220 L 75 bhp
I recommend buying a shop manual for your truck.
An improperly installed timing belt can cause severe damage to the engine.
Incorrectly installed, this can result in permanent damage to valves, their stems and even pistons and connecting rods.
Mar 14, 2015 | Ford Cars & Trucks
Why will the gears of my actros truck not workafter fitting new clutch
well a description of the problem would be a big help
does the gear crash when the clutch is pressed in
can the gears be engaged cleanly when the engine is stopped
did you install a single plate clutch or duel plate clutch
if the gears worked properly before removing the box , then the problem will be in the clutch plate fitting ( wrong way round and the hub is hitting on the flywheel bolts or duel plate on clutch bub is incorrect hitting on the other clutch hub)or the gear shifter installation after fitting the box
Sep 13, 2014 | Mercedes-Benz Mercedes Bentz Actros Semi...
My 1983 toyota ran hot now it wont start
a malfunctioning coolant temperature sensor will often send incorrect information to the vehicle's on-board computer. As a result, when the vehicle reaches a normal operating speed the sensor may relay an incorrect signal to the computer that the engine is overheating resulting in engine shutdown. The vehicle will not be able to start again until the engine has completely cooled. also check coolant level and make sure the coolant radiater fans are working. check for any leak in coolant system, that would cause car to overheat.
May 02, 2012 | 1983 Toyota Pickup
Have a1998 olds intrique has random misfire 1 an 4 po300 also service vechicle trac off anti lock and a flashing service engine light just had oil chand\ge and plugs and oil filter. also may have a...
Sounds like ignition problem - I would first check the plug wires carefully for cracks, routing problem (flashing to engine), and incorrect order, and if all OK then check the plugs for contamination/incorrect gapping.
Dec 10, 2017 | 1998 Oldsmobile Intrigue
98 ford exployer wont start getting fuel,has spark and compression???
Haynes repair manual.
I didnt put the first five in becuase of the things you said the vehicle is doing you didn't need them. but this is straight from the Haynes manual
6. water in fuel
7. wet or damage ignition components
8. worn, faulty, or incorrectly gapped spark plugs
9. Broken, loose or disconnected wires at coil or faulty coil
10. timing chain failure or wear affecting valve timeing
11. Fuel injection or engine control system failure
Jan 07, 2010 | 1998 Ford Explorer
Can i install a cd player in a 1991 pontiac sunbird?? becuase the the factory radio is so small and the a/c vent is close by?
The radio will be installed in the location of the tape player.
Metra Kit# 89-30-3310
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 24, 2009 | 1991 Pontiac Sunbird
Foxconn A74MX motherboard will not pick up my PCIe Graphics card
disconnect everything except the power supply, the power on switch, one stick of memory and the graphic card (if you don't have onboard adapter), turn it on and see what happens.
Mar 28, 2009 | Foxconn Computers & Internet
Ink cartrige wont work
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
