Question about Microsoft Windows Vista Ultimate Edition
C++ graphics(dos) fullscreen
Is there any software launched for the same...?
UYTUTYU
Posted on Apr 13, 2008
How can i remove the window frames in Photoshop?
If I understood you right - the answer is TAB key on your keyboard. This will hide all toolbars and panels. Shift-Tab will hide everything except options and toolbox bars. You could also find F key useful - it rotates through fullscreen modes. 10_17_2013_6_07_22_pm.png
Sep 24, 2013 | Computers & Internet
Can i play dino park tycoon onmyhp 530
Upgrade the video card and your RAM. This is a graphics chip designed for Vista and Laptops. And as your laptop graphics is not upgradeable the only thing that may help is the RAM. But don't hold your breath.
May 05, 2012 | Nvidia Geforce 9300GS, PCI Express Video...
How i open two or three ids at a time on yahoo messenger
How To Run Multiple Yahoo! Messenger Accounts On Your PC
1. Go to Start > Run.
2. In the Run box, type regedit and click OK button to launch the Registry Editor.
3. Now, navigate to HKEY_CURRENT_USER > Software > Yahoo > Pager > Test.
4. On the right pane, right click , choose New > DWORD value.
Posted image may have been reduced in size. Click image to view fullscreen.
5. Rename the new registry key as Plural.
6. Double click on the "Plural" registry key and assigns 1 as the value data.
Now, you can login to multiple Yahoo! Messenger accounts on your PC. If you want to login to two YM accounts, you will need to launch the application twice in order to get two login screens.
I hope this information will be helpful. Thank you for using FixYa!
Feb 19, 2011 | Computers & Internet
I executed simple C++ program but when i executed graphics program like to print circle,then the window closed and displayed a following message. 16 bit MS-DOS Subsystem C:TC BINTC.EXE The NTVDM CPU has...
If your operating system is win 7 or vista,
1,Locate c++ program file right click and goto properties
2,Untick or unselect RUN IN FULLSCREEN option.
Then your problem will be solved.
Jul 27, 2010 | ASUS M2N-MX Motherboard
Football manager 2008 unable to open fullscreen mode on notebook
Guess you need to change your graphics card on it or check the settings of this game under video options.
May 11, 2010 | Computers & Internet
C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
Jul 31, 2009 | Computers & Internet
Hp laptop,,vista os,,turboc not working in full screen
In order to get the full screen use the key combination of Alt and Enter
If you right click on program, in properties,you'll see an option called program compatibility. Make compatible with earlier versions
Jul 28, 2009 | HP Compaq 2510p Notebook PC
No fullscreen support in my laptop
full screen mode just on the tft screen or to an external device ie a projector or monitor or what exactly ?
Also are there any options in the bios of the laptop to enable full screen mode or if you update the graphics card drivers does that help ?
Apr 14, 2009 | Computers & Internet
Actionscript
using fs command you can make your flash presentation fullscreen the code is given bellow this.fullscreen_btn.onRelease = function() { fscommand("fullscreen", true); }; this.unfullscreen_btn.onRelease = function() { fscommand("fullscreen", false); };
Sep 01, 2007 | Macromedia Flash MX
Microsoft Windows Vista Ultimate Edition Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
