I put the wrong adapdator onto my Seagate external drive and seem to have burned out the motor. It does not spin up now and the red light on top blinks. Seagate will charge a fortune to recover the data. How can I get the data and/or get the thing spinning again.
  • 13,433 Answers
You can take the harddrive to a prefessional data recovery
the harddrive itself is done for, but the data can be saved, will cost thought.
Posted on Apr 11, 2008
  • Ekse Apr 11, 2008
    you can open the case and check if the harddrive itself is working or burned. if the harddrive is ok then you would just need to replace the external case and adapter.
  • 796 Answers
It is not possible by us to do anything..
take it to a service center...
they might replace the board on the hard disk...
may be by replacing it may start working again
  • 2,326 Answers
Is this an external hardrive?
  • Jaime Hernandez Apr 11, 2008
    sorry I miss that part about the external part.
    I would suggest to try to remove the hard drive and installed on a computer to try to recover the data.
    I would think that this device has a fuse or a diode to protect the hard drive against shorts.
    If the motor does not spin, it does not mean is damage. The part that will get damage will be the circuitry where the motor is connected to.
    I would suggest to check inside the enclosure and look for a hard drive with a exact model number, and take the board out to install it on the defective one. It might a cheaper way to recover the data.
    Let me know if you need further assistance.
My external hard drive fails to spin
The hard drive needs a proper regulated power adapter for the hard drive to work.
If the hard drive is a 5.25 inch drive it requires 12 volts and 5 volts power supply.
If the hard drive is a 3.5 inch drive it requires a 5 volt power supply.
Apr 10, 2012 | Seagate Computers & Internet
I have an external Seagate Freeagent 1.5TB drive, purchased at Costco roughly 2 yrs. ago. My two yr old knocked it about 10 inches onto a carpeted floor (which didn't seem like a big fall) but now it will...
More you try to use, you'll have less chance to recover the data. Try consult with seagate service center to fix the drive first before send it to data recovery company.
Mar 15, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
I have a Seagate Free Agent Desktop External Hard Drive. I cannot get any of my computers to access the drive. I fear the drive has crashed.
get linux puppy and boot the cd while your hard drive is plugged in, if you can mount under puppy linux and see your info choose the info you need and offload onto an external usb, copy the files over, dont move them as if disk is corrupt you could lose info, then reformatt the drive, just to let you know there seems to be alot of hard drive issues with seagate lately
Feb 14, 2011 | Seagate Computers & Internet
St3500320as bios not detect,i am using it as external hdd, once i used wrong power supply (original 12V, wrong 19V)and after that it was no detectable  in bios anymore, i can see some places on board...
I'm not sure I understand you correctly but this is what I think.
You tried to use the drive in an external case and the power supply was 19v. The drive really needs 12v. When you put it back inside a PC the bois does not detect it.
Id say it is destroyed. Do not wast you time with it.
If you think it is burned then it probably is.
Sep 25, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Twin drives in an external HDD, and it quit, but I can hear them working. The fan also quit too.
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware
May 20, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.8 300 Gb - power problem
it really all depends on how far the damage is. I have swapped the controller board on a hard drive that had failed with one from an identical drive and was able to retrive the data. This is not a very common thing that works. Your data is most likly still entact on the platters. However, if the motor is damaged it would require expert and very expensive help to recover the data.
If you have access to being able to swap controllers then try it. This may get your data back.
Jan 13, 2009 | Seagate (ST380011A) 80 GB IDE Hard Drive
Slightly dropped seagate external hard drive, recover data??
please use stellar phoneix software
that will do your job surely
Mar 16, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Imation SD-USB-M2 SuperDisk USB(MAC)
Sounds like a dead (or jammed) motor -- the one that spins the media. It's relatively easy to open the case, disconnect the USB-to-IDE interface adapter from the 40-pin IDE connector, and go onto eBay to find any "internal" or "external" LS-120 device, and swap it in, to replace the "not-spinning" device.
Jan 26, 2008 | Imation (01946) External Floppy Drive
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
