Check engine light? check oil level, low oil possible engine damage.is there gas in tank?guages can lie, add a gallon if not sure. when key is turned on, not all the way to start, can you hear the fuel pump, an electric motor sound? have someone listen above the tank with trunk open or listen under tank. past this, check if spark plugs are working, remove a plug, put wire back on, rest plug on metal to ground, turn motor and check for spark. please rate answer.
Testimonial: "Thanks for the Help. Oil was in the minimal.... Hope the engine still ok. Check all the rest and everything is fine. Talk with the Honda representative and he thinks is the ignition coil????? He is coming next week to have a look... If I don't manage to fix it over the weekend. Cheers :-)"
