Question about Dell Microsoft Windows XP Home Edition
Can't get a connection back on my ISP (embarq).
All else works find. Embarq check connection its good. Just does not connect to web. I get page that read (Page not found). Internet Option for internet is set to go to MSN so that is good. So what next ? Please HELP!
  • 3 Answers
Hello firesnake,
This is a message from Lamont with Embarq Customer Support. We would first like to thank you for your business and apologize for any frustration you may have encountered with your installation. We strive for complete customer satisfaction on every issue and are reaching out to our customers that are not completely satisfied. Please reply to the following email address if you are still unable to complete the installation or have any additional concerns. Thank you for using Embarq, your complete communications solution.
Lamont L.
SMNP.Lamont.l@embarq.com
For additional support please visit http://www.myembarq.com/contact_us.php or call 1-877-646-3282
Voice | Data | Internet | Wireless | Entertainment
Posted on Apr 22, 2008
    Problem Solver:
  • 7 Answers
If you have dial-up, go to tools>internet options>click "always dial my default connection" or if you have broadband click on "Never dial a connection" These settings are found in Microsoft Internet Explorer 5 or higher.
Posted on Apr 16, 2008
I can't get my belkin 37E1 to talk to the modem an embarq 660. I have a gateway computer running xp
ISP : EMBARQ
Step 1 : Connect Belkin - Computer ( Computer Should go to Any one of the four the Grey colored Wired slot)
Step 2 : Make sure the embarq modem is not connected to the belkin
Step 3 : Open the Router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 4 : On The Left under LAN Setup Click Lan Settings
Step 5 : Leave the Password Blank And Click Submit
Step 6 : Change the LAN IP To 192.168.3.1
Step 7 : Click Apply Changes
Step 8 : Connect EmbarQ modem to the Yellow Slot in the Router
Step 9 : Connect Modem - Router - Computer ( Check if you Have Internet !)
Setting Up A Wireless Connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.3.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 17, 2010 | Belkin (F5D7231-4) Wireless Router
I have a Belkin mdl. f5d8236-4 v2that worked great
if ur internet service is embarq then u need to first unplug the modem from the router
because the embarq modem and belkin has the same ip address
so jus connect the computer alone to router and power on the router
then login to router setup page with 192.168.2.1 then on left side click on "LAN SETTINGS"
IT WILL ASK U FOR A PASSWORD THEN LEAVE IT BLANK AND CLICK SUBMIT
then change the lan ip to 192.168.5.1 and then click on apply changes then go ahead and click on OK
once it is done then plug ur modem to the router then unplug the powercord of router then plug it back again --- then u can have the modem and internet light to be solid --- then u can access the internet
Jan 27, 2010 | Belkin F5D8236-4 Router
I have a laptop comp i just got a desk top comp i have embarq broadband internet which comp do i pit the cd into to install and which comp do i hook up the embarq box to?
It sounds as though you will need to get router to allow the sharing of the Internet between the two computers. Using a router makes it much easier to share an Internet connection between multiple computers. You would connect the Embarq box to the router on the WAN port, and then connect your computers to the LAN ports of the router. You may also want to get a wireless router in the event your laptop has a Wi-Fi connection.
Oct 06, 2008 | Computers & Internet
Embarq online security is causing a problem with my Quickbooks programs it says the security system is interfering with ActiveX controls.
Hello cncurfman,
After reading your issue, I would recommend you contact our RescuIT team at 866-626-8154 or visit their www.embarq.com/rescueit page for more information. This is a team that can support pc concerns with conflicting software.
Lamont L.
embarq_lamont@embarq.com
For additional support please visit www.embarq.com/freetv or call 1-877-646-3282
Aug 11, 2008 | Computers & Internet
2WIRE 2701 router
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Aug 04, 2008 | 2wire 2700HG-B Router (2700HGB)
Belkin F5D8233-4 Setup Problems
Hi Erich. Don't rate this til we're done. Do you have DSL connection?
May 21, 2008 | Belkin (F5D72304F5D7000) Router
Acer desktop 90 days old
have your service provider check your router and WAN conection. Also request to look into the airial cable
Mar 22, 2008 | Acer ALN 325 Network Adapter
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Jan 05, 2008 | Computers & Internet
Zoom X5 adsl with Embarq high speed internet
Hello wil31nc, Lets get back to basics, what I want you to do is to turn off your windows firewall for now, reset your router/firewall to its default configuration. How to do this This can be found in your users guide (Hard Reset). Once this is done then I want you to connect your DSL upto the Router and your PC to one of your LAN ports. It (the router) should give you an IP Address at this point, then I want you to use your web browser to log into the web UI of the device once there you will need your ISP provided login ID and password. choose PPPOE and after you input those (login and password) into the proper dialog box. then from your PC try to perform these tests: ping to the router 192.168.1.1 (ping 192.168.1.1) ping to the ISP gateway address (ping xxx.xxx.xxx.xxx) (xxx=The octets of the address of the ISP router) ping to a site on the internet (ping www.dslreports.com) you shouls at least be able to ping to the gateway (ISP router) of your ISP. I beleve that this will get you up and running
Sep 03, 2007 | Zoom (56540000F) Firewall
Computers & Internet Logo
105 people viewed this question
Alun Cox
