Canon PIXMA MP240 All-In-One InkJet Printer Logo
A
Anonymous Posted on Jun 10, 2010
Where is the ink cartrige in Canon MP240 located in printer?thank you
Chee Seng
Level 2:
  • Expert 284 Answers
  • Posted on Jun 10, 2010
Chee Seng
Expert
Level 2:
Answers
284
Questions
0
Helped
163864
Points
706
Lift the scanner up, then you will see the carriage holder moving to left side. After that you will notice the cartridges are inserted with the carriage holder.
1 Related Answer
  • 6688 Answers
  • Posted on Aug 02, 2010
SOURCE: Where is the ink cartrige in Canon MP240 located
The cartridges are under the scanner and stay off to the right side of the unit except when printing or when you lift the scanner unit cover while the unit on. If the cartridges returns to the right, close the scanner unit cover and then reopen it. If the cartridge carrier doesn't move, make sure that the unit is turned on.
The black ink goes on the right side.
I hope this helps.
(if the cartridge holder doesn't move when the unit is on, check that nothing is blocking the path.)
I refilled my ink cartridge for canon mp240 but the black ink light is still flashing and I can't print. Ijust put ink in so i know it is full. How do i fix this problem
Did you use proper ink?
Try to disable "check for ink level" in printer driver.
Then try to clean connector plate of cartridge and printer with alcohol.
1helpful
How do i replace the ink in my canon mp240 ?
To replace canon mp240 cartridge ink, one should follow the manual. Download the manual from this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#BrochuresAndManuals
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
10helpful
I hope this helps.
1helpful
After installing new ink cartridge, low ink warning. had cartridge ink replaced. need to remove the warning
try this, be sure you have the recommended inks.
http://pdfdatabase.com/canon-pixma-mp240-all-in-one-inkjet-printer-manual-repair.html
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=17161#SNAModelSuppliesAct
your vote counts,
regards,
1helpful
Where is the ink cartridges located on the canon pixman mp240 printer? cant find it!!
Go to this web page:
MP240 Support
In the search box type, replace ink cartridge and then click Search.
The top answer should be "How do i replace the ink cartridge(s)?"
Click on that link.
Instructions for replacing the ink are given along with pictures that show how to access the cartridges.
Thanks for using Fixya.
PS. You might want to save that page above for future reference. The other tabs have a lot of info including drivers, manuals, and more.
3helpful
How do you change the ink cartriges
open the scanner and scanner tray..while the poweer is on..the cartriges will go to the left..then with a llittle pressure push down on the cartridge it will pop out
7helpful
2answers
I need to change the cartridge in my cannon printer. how do i do this?
Go to:
Canon MP240 Support
In the search box, type in replace ink cartridge. Click Search. Red links will be shown. Click on the one that says, "How do I replace the ink cartridge(s)?
A nice little tutorial will appear with step by step instructions.
28helpful
3answers
Reset ink counter canon mp240
Press the red button in the right bottom, the one in witch is a red triangle. Press it for 15 seconds. Ciao!
old marine
old marine
ZJ Limited
ZJ Limited
