Question about HP Pavilion A730N (PJ510AA) PC Desktop
Power supply I turned off my computer and went to bed and the next morning it wouldn't start up. The light in the back at the power supply is lighted but very dim and nothing happens when you try to start it. There was no storms or power outage issues. Thanks
    Sergeant:
  • 202 Answers
Hello enirehtac
HERE is a link to HP's instructions for trouble-shooting power supply-related issues.
Please, follow the steps outlined there and post back here w/ the results, your observations, and any comments or questions you might have.
** Please, don't assign a rating to any of
** the experts' recommendations until your
** problem has been resolved or diagnosed.
** Once ratings are assigned, the problem
** will be closed and we won't be able to
** continue to assist you. We WILL keep
** working w/ you until your problem is re-
** solved or diagnosed.
Thank you
BJ @:)
Posted on Apr 11, 2008
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello enirehtac
    How did it go? Did the information and link I provided you w/ enable you to determine the cause of your computer's power issue?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you.
    If
    it is the case, would you kindly take just a moment to reward my
    efforts at helping you w/ a FIXYA rating for my "solution"? I would be
    very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
Interior Dash Lights dim, brake & battery warning lights flash on and off.
Sounds like your alternater, get a multimeter set it to volts start the car then check the battery is getting 14 or over volts from the alternater to the battery , if your getting less than that it's not putting enough volts back to the battery to run the car with good luck colin
Jun 15, 2017 | 2003 Mitsubishi Galant
Just downloaded new books. Was reading one that night. Turned it off and went to bed. The next morning, I tried to turn it on to read more and it wouldn't come on. It was charged - not the problem. ...
Probably the its a frozen reader issue, try these steps:
1. Connect the reader to the computer
2. While the reader is connected hit the reset button for 3 seconds, and make sure the redlight comes on.
3. Leave the reader connected for 15 minutes, then disconnect it and see if operational now
4. If the reader still not turning on, try the reset and slide the power switch.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jun 23, 2011 | Sony Reader Pocket PRS-300
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
The computer has on occasion crashed for no apprent reason. I had the power supply out and it has normal light indications until it i plugged into the mother board. I have had itwork normally, for a...
Bad Power Supply. Weak voltage power rail.
Bestec is a low quality power supply. Used to save the computer manufacturer money.
Also, a Power Supply with a weak voltage power rail will put out enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on, and/or keep it on.
A) ALL the LED lights use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
Replace the Power Supply. Clean the inside of the computer out, with a can of compressed air for computers before installing.
What is the computer manufacturer name, and Model Number. The Model Number is on the back of a desktop computer tower next to the Windows product key, or up on the side of the computer tower.
Post back in a Comment.
Regards,
joecoolvette
Dec 04, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
My monitor will not turn on, it was working fine yesterday and then I turned it off when I went to bed and when I woke up this morning, the power light is weakly flashing a dim yellow, but it wont turn on.
kmbass24, Could be "black screen of death" problem. The problem is inside the monitor! Most likely a power supply problem. If not handy with soldering iron, solder wick, removal/install of bad filter capacitors, and use of DVM then a tech will need to troubleshoot unit. Some units can be repaired for less than $12 in parts!!! It's the charge for labor that gets you in the end. $20 min per hr. Your monitor is no different than any other brand. Go to YOUTUBE and view some typical BSoD repair vids of "LCD monitor disassembly" LCD monitor repair" FYI and learn what the 2 common ROOT CAUSES of BSoD are. Hint for you is this: Have you seen the NEW style screw-in, curlie-Q, energy saving compact fluorescent LIGHT BULBS! Very similar technology is used to light-up your LCD panel to enable you to SEE what is on the display!
If this was of some interest, rate this response on fixya. bye for now.
12fixlouie
Nov 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Display Screen Went Dark...
This would seem like the power supply is broken and the computer is working off the battery or the setting need to be changed in power management. Whenever you disconnect the power supply and work form the battery, as power saving mode, windows will dim the back light to the display. First check if the power supply is charging the battery and then check your settings in the following: Start menu -  Programs - IBM - Battery MaxiMiser Wizard. Follow the steps until you get to the LDC display level. You may need to increase that.
Sep 09, 2008 | IBM ThinkPad T23 2647 Notebook
Won't come on
Replace Ic 901 (STR-M6511) and check for bad capacitors in the power supply.
Jan 26, 2008 | Televison & Video
HP Pavilion A730N (PJ510AA) PC Desktop Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
