Samsung SGH-e315 Logo
Posted on Apr 11, 2008
Samsung e315 one sim only
I was trying out the many codes that samsung has, i entered the code (*0141# send) then i saw "PERSONALISED" after i put a different sim in my phone it ask for a password, i entered all 0s and it didnt work, i entered my phone code it didnt work either, when i put the original sim back in it doesnt ask for password, how can i undo this password error? i tried the formattin codes but all they done was change the phone code to default and delete the files,
  • 131313131313 May 10, 2008
    I WAS UNLOCKIN MY PHONE AND IT ASKED ME FOR A PUK AND I DONT KNOW WHAT A PUK IS
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
673
Points
6
Hi! good day! try this code
2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
1 Related Answer
Anonymous
  • 3 Answers
SOURCE: pls help
hi! good day! try this
#*7337# - UNLOCK
*2767*688# - UNLOCK
8helpful
3answers
HOW CAN I DISABLE SIM LOCK
Contact the service provider....
My samsung D900 has a sim lock, i forgot my code
YOUR MUM HAS GOT E BIGGER **** THAN ME MATE!! AND PLUS I'VE GOT AIDS!! AND HIV BOY!!
8helpful
3answers
I forgot my cellphone number and pass code. What should i do?
remove ur sim card and place the battery back in w/o any sim card. Then enter this code *2767*3855# press send. then insert the sim card again and check if it will resolve it. NOTE: before you perfrom this i would like to advised u that everything will be deleted on the phone's memory it will restore back to the factory settings
2helpful
Phone locked
WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
Before you start, make sure the battery is charged and all security codes or PIN codes or watever are disabled so we dont have any code prompts interfering with this method.
1. Turn off the mobile phone.
2. Insert a "Non-accepted" SIM card (sim card that wont work) half way in so that when you turn on the phone, it still says "Insert SIM".
3. Turn on the phone.
4. Enter the following code and wait patiently for phone to reset:
*2767*2878#
5. Once reset has completed, the phone will still say "Insert SIM". This is where you need to push the sim card all the way in. You can use a paperclip or a tiny object to push it in if you have difficulty. IT IS IMPORTANT THAT THE PHONE REMAINS ON AT THIS STAGE (TRY NOT TO LET BATTERY FALL OUT) IF BATTERY FALLS OUT, DO NOT PANIC, JUST START FROM STEP 2 AGAIN.
6. Enter the following code and wait patiently for phone to reset:
*2767*3855#
7. After reset is completed, SIM should work and also the reception. Don't get excited, its not unlocked yet.
8. Now we want to make it permanent. First check what locks need to be deactivated with the following code:
*#7465625#
a)
If Network Lock is "Active", put in the following code:
*7465625*638*00000000*00000000#
Message should be "Network Lock has been personalised" or similar.
Then:
#7465625*638*00000000#
Message should be "Network Lock deactivated" or similar.
b)
If Subset Lock is "Active", put in the following code:
*7465625*782*00000000*00000000#
Message should be "Subset Lock has been personalised" or similar.
Then:
#7465625*782*00000000#
Message should be "Subset Lock deactivated" or similar.
c)
If SP Lock is "Active", put in the following code:
*7465625*77*00000000*00000000#
Message should be "SP Lock has been personalised" or similar.
Then:
#7465625*77*00000000#
Message should be "SP Lock deactivated" or similar.
d)
If CP Lock is "Active", put in the following code:
*7465625*27*00000000*00000000#
Message should be "CP Lock has been personalised" or similar.
Then:
#7465625*27*00000000#
Message should be "CP Lock deactivated" or similar.
e)
If SIM Lock is "Active", put in the following code:
*7465625*746*00000000*00000000#
Message should be "SIM Lock has been personalised" or similar.
Then:
#7465625*746*00000000#
Message should be "SIM Lock deactivated" or similar.
3helpful
Can't remember phone lock code
Puk code is needed when you have entered the pin code wrong 3 times.
If you have a phone lock code on it and you can't remember to code try the defaults 0000 1234 12345 00000 etc. if you can't unlock it contact your dealer with proof or pruchase or contact a samsung service center, you can get those details from www.samsung.com you will most likely have to send the phone to be unlocked.
you can try entering these two codes without a sim card in the phone. write them where you would write 911 phone should restart. then insert the sim card and try turning the phone on.
*2767*3855# = Full Reset
*2767*2878# = Custom Reset
If these don't help then contact samsung for unlock service you will most likely have to send the phone to a service center.
3helpful
2answers
Pin code request when turning phone on
hey everyone.
i have read a couple of threads i have found on the internet and i have tested this on my samsung sgh-c450 locked to telstra. no computer is needed (or cable). i hope this helps anyone with a samsung. WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
4. Aant. Harry----- punt 4 is vervallen ivm met het verwijderen van de emei-code.
*2767*3855#
*#7465625#
Aantekening Harry: Om de codes in te voeren moet je een keer op de rode toets (naast C) drukken, zodat je in het beginscherm komt. Dan kun je codes intoetsen. Dus geen codes intoetsen als je in het keuzemenu zit.
a)
Then:
b)
Then:
c)
Then:
d)
Then:
e)
Then:
"a)" is the common one that usually is the only one need to be done but if other locks are active, i think its best to disable them now while you have the chance.
Now you have unlocked your phone!
Tested on:
SGH-C450
Please test this!
Thank You.
1helpful
Pls help
#*7337# - UNLOCK
*2767*688# - UNLOCK
Pls help me to get back into my samsung G800 phone
HI PLEASE REMOVE UR SIM CARD AND POWER ON UR MOBILE AND ENTER *2767*2878# THIS FORMET UR MOBILE AND U USE UR PHONE AGAIN. KEEP VOTEING THANKS.
Pls help me
HI U REMOVE UR SIM CARD AND POWER ON UR PHONE AND ENTER THE CODE *2767*2878#. KEEP VOTEING. THANKS
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
