Question about Acer AL1715 17" LCD Monitor
Acer AL1715b LCD monitor
Monitor image distorts badly (shimmering and pulling) when it has been turned on for a while. The time that it was on before it distorted was reducing each time it was turned on. It looks fine before it starts distorting. None of the electrolytics on the circuit board are swollen, or look at all distressed, but there is some corrosion around the soldered pins of the VGA socket on the circuit board. Here is a pic:.
  • Don Batten Apr 11, 2008
    Thanks for the prompt reply! Yes, I've built all sorts of electronic gizmos, but LCD monitors are new to me. This one is a gift from my son and has not been used much. This model has only one PC board with everything on it: power supply, signal processing and LCD panel drivers. It is part number: 790361200611. Thanks. Picture:
  • Anonymous Jun 14, 2008
    I have the same problem, the monitor starts to develop black lines and distorts badly. I tap it a few times on top and it clears up.
  • 472 Answers
You obviously have some technical background which is going to help alot.
What I need to know is the part number from your video board firstly. I may have a schematic here for it, though there are about 5 types for this one model.
Secondly, since you appear to have electrical knowledge I will also assume you have a half decent multimeter.
With the unit powered on, (you will need to connect the video cable and have the pc running so it dosn't go into standby)measure the voltage on the connector between the powerboard and video card. In particular we need to check the +5v line to see if it is fluctuating even a small amount. This +5v powers the panel itself, so any fluctuations will cause inherent video problems.
If possible, could you also submit a photo of the entire video board, and another of the power board just for my reference.
Posted on Apr 11, 2008
  • Peter Thompson
    Peter Thompson Apr 11, 2008
    Near the transformer there are 2 rectifiers. Check there are no shorts on either of those, particularly the one on the right in the photo.
    Also check the caps in that area for any that have gone dry. That will cause the same issues of course as those that have exploded.
    The closest schematic I have here is for an AL1717x but it's all schematic, no block diagrams or anything else I can use to compare it to the board you have.
    send me a garbage email and I will email it over for you to go over if you'd like it.
    email is
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
My monitor comes on for approx. 1 minute then blacks out. Any hope?
Look at the power supply and caps per Loiue suggestion. AL1715b/
Capacitors kit: he can make you a set of caps for you.
Sep 08, 2010 | Acer AL1715 17" LCD Monitor
Monitor is distorted
You may want to open it up and inspect the caps (bad caps with bulging tops) as shown in my pictures here:
Bad DC filter caps can cause alot of strange symptoms.
Apr 30, 2010 | Acer AL1716 17" LCD Monitor
MY monitor is very distorted.
Try disconnecting and reconnecting the cables. Sometimes this is a cable connection issue.
Mar 20, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
My acer,mod. 1715
Rich most likely this monitor needs capacitor replacement if you can solder you can do it, you just need to order or get the bad capacitors that need replacement so you need to open the case and get at the power board. once you can get at the blown caps you can see whats damaged and what is OK usually it is 1 or 2 capacitors at about 50 cents each. and about 1 hour of your time.
let me know what your doing, good luck
Oct 18, 2008 | Acer AL1715 17" LCD Monitor
Ghosting of the image
no it is a board replacement at best, so i would look into replacing the vga board or getting a new monitor and selling the damaged one for parts with the issue listed
May 11, 2008 | Acer AL2216W LCD Monitor
ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Distorted picture on 20 inch monitor
second problem some unit on the board in the monitor has gone bad return it for an exchange
first problem the display setting need to be set correctly
Dec 28, 2007 | Acer AL2016W 20" LCD Monitor
Horizontal banding that looks like Interference
i would take this in for a service check could be issues that need resolving from a service standpoint not a simple driver or resolution fix
Dec 18, 2007 | Acer AL2216W LCD Monitor
Acer AL1715 17" LCD Monitor Logo
1,019 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
