Question about HP 1040 Plain Paper Inkjet Fax
Ink Cartridge not recognized
I just got this fax machine and loaded the ink cartridge but when I close it it keeps saying install ink cartiridge...i've checked everything and I did it properly 5 times now! What am I doing wrong?!
  • 3 more comments
  • Anonymous Apr 17, 2008
    Message says Replace Ink Cartridge when in fact copies can be printed. Cannot receive FAXes. GK389@AOL.COM
  • Anonymous Apr 18, 2008
    ink cartride was changed and display still read "change cartridge". the machine will not print.
  • Anonymous Apr 30, 2008
    yup me too
  • Anonymous May 06, 2008
    Same thing. New cartridge, and it won't accept it. Put in the old cartridge and it starts trying to work (only there is no ink left!).
  • ssha Dec 01, 2008
    I am using the genuine HP cartrige - still getting the same error.
When i want to print,message box will display ink cartridge cannot recognized..i try again and again to repair it..but the problem is same..my friend prefer to buy a new one but i don want because this is a new ink..maybe this ink is not original ink,i modified an ink to be refill.
Posted on Sep 15, 2008
    Genius:
  • 2,120 Answers
Use only Genuine HP ink cartridges.
Posted on Sep 01, 2008
Install ink cartridge after the installation
INK CARTRIDGES ARE TIME SENSITIVE, check if the date in the box was current or expired.
Nov 19, 2013 | HEWLETT-PACKARD HP 2140 Fax
How can i install the ink film?
Hello :
If you mean change then :
1: Turn the power off on your fax machine.
2: Open the front or top control panel Make sure not to force the door open.
3:Locate the ink cartridge. Gently pull the cartridge out. Set the cartridge aside.
4:Take the new cartridge out of the package and reserve the packaging. Remove the protective covers over the copper connectors.
5:Insert the new cartridge into the fax machine with the brand label toward you. Now place the old cartridge into the plastic wrapping and box that you reserved from the new cartridge. Recycle the old cartridge or dispose of it in the garbage.
6:Close the fax machine's access panel. Turn the fax machine's power back on.
Warning:
1:Touching the copper connectors on the ink cartridge could damage the cartridge. 2:Make sure that you purchase the correct cartridge for your fax machine. Purchasing the wrong one could damage the cartridge or your fax machine. good luck . please don't forget to rate !
Apr 04, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
No cartridge
A “No Cartridge” error message on 1960c products is caused by third-party (non-Brother) ink cartridges
leaking ink onto the Ink Sensor PCB and shorting out the cartridge sensor. In order to resolve this issue, a new
Ink Sensor PCB will need to be installed.
Jun 11, 2009 | Brother IntelliFAX 1840C Plain Paper...
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
In Use/Memory FAX after changing ink cartridge
I had the same problem - it would not print the faxes as the machine would not recognize the generic cartridge - I had to get the official Canon cartridge to get the faxes to print out of memory.
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Re install ink
I know this is a dumb question but did you remove the tape off he bottom of the ink cartridge? Also sometimes if you are using a generic ink cartridge the machine may not recognize it. Make sure the cartridge is seated in properly and that it is in the correct location. (not color spot). Hope this helps. John
Sep 07, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
HP 1040 Plain Paper Inkjet Fax Logo
999 people viewed this question
Ben Johnson
