Question about Audiovox VOH1502 15 in. Car Monitor
Question escalated to PREMIUM Level
FYI: BELOW are the exchanges between myself and the Audiovox support(???) folks.
I have to think if there was an actual wiring diagram and a parts exchange available I MIGHT be able to fix this.
BTW I can work-around the "remote" issue.
TIA, Jim
: James J. Gunther To : Brian Woods
Hi Brian,
I think you may have inadvertently delete my latest message (See BELOW)
I'd like to get a copy of the appropriate pages of the service manual so I can, possibly, effect repairs.
Also, elec volume pad part availability.
Subject : FWD: RE: Read: Troubleshooting/Repair suggestion
Date : Thu, 8 Nov 2007 18:31:00 -0500
Linked to : Brian Woods (GMCAudiovox)
To : Brian Woods
Hi Brian,
As suggested, I "unplugged" the VOH1502 in hopes ofd, perhaps, re-setting the uncontrollable volume problem.
Re-installed and found the same problem.
As returning the unit for repaid at a flat rate of $250. makes NO SENSE, I'd like to take one more shot before I give up.
I suspect the unit may need a new control pad but I can't figger a way to open the unit.
Is there an on-line service manual available or perhaps a technician might be able to send a PDF of the pertinent sections so I can inspect/clean/check the contacts.
Also, of course, is there a list of replacement parts?
TIA, Jim
Jim Gunther, Principal
Harvard Aimes Group
www.RiskManagementSearch.Com
Phone 203-933-1976
---------- Forwarded Message ----------
TO: "James J.Gunther"
DATE: Mon, 8 Oct 2007 12:09:32 -0400
RE: RE: Read: Troubleshooting/Repair suggestion
Most likely you will not find a store bought universal remote,
cable/satellite box remote or other manufacturer's universal remote with
our coding/frequencies in there. These universals deal with primarily
home consumer electronics, almost no mobile electronics. Note that the
"4-digit code" is just a reference # for the coding/frequencies already
stored in the remote from the remote manufacturer. This "code" is
arbitrary and created by the remote control manufacturer, not by the
device manufacturer. If the remote doesn't already have this
information stored in it, the only way you can add this is if it is a
"learning" remote. If yours is a learning remote, follow the
instructions in the manual for your learning remote control for
"teaching" the TV's remote commands to it.
The best way to think of it is the 4-digit codes are like the page
numbers in the index of a book, the IR coding/frequencies are the text.
If the correct coding/frequencies (text) isn't already programmed into
the remote (book), you can not add the code (turn to a page that's not
in the book) after the fact, unless it is a learning remote control.
As far as the volume issue, try removing power from the TV to reset the
software. See if that helps. Beyond that, it could be a stuck volume
control button or other hardware related issue.
If you need further assistance, feel free to contact us.
Thanks,
Please use the reply button with all correspondence.
Brian Woods
Technical Services
ASA Electronics
Elkhart, IN
Fax 574-266-1533
www.asaelectronics.com
-----Original Message-----
From: James J.Gunther [mailto:JgmG@RiskManagementSearch.com]
Sent: Tuesday, October 02, 2007 10:44 AM
To: Brian Woods
Subject: re: Read: Troubleshooting/Repair suggestion
Hi Brian,
I sent a note last week (appended BELOW) regarding my Audiovox LCDs
Any help? or perhaps you can direct me to the proper person?
TIA, Jim
Hi Audiovox RV Service Group,
I recently acquired a motorhome which had an Audiovox (#VOH1502) monitor
installed in May 2005.
I also the VOD1048 in the rear bedroom.
The TV is very nice for my application.
I have 2 issues with the #1502 I just can't 'figger. I hope you can
help. (WEB LINK or PDF response will be fine.)
#1.) In as much as the Audiovox Remote is missing I need CODE #s to
program a typical all-purpose remote.
I DO have Direct TV Satellite but have been unable to find appropriate
code for that controller either.
#2.) The TV will not hold steady volume. For no apparent reason, the TV
will increases volume up to 100.
When the volume spikes, it shows the "volume grid" on the screen.
This problem is persistent. Manually click-it-down and in moments or
minutes it will go-right-up again.
Any suggestion, part replacement or work-around would be appreciated.
Harvard Aimes Group
Phone 203-933-1976
  • 363 Answers
You can search this database for the service info you seek about your tv here:
http://www.samswebsite.com/photofacts.html
Most service manuals with schematics cost about $27.95 for the PDF version of it, otherwise the paper version is about $15.00 more for handling and shipping.
You will need the chassis number of the unit in question in order to search for it. I hope this helps!
Good Luck!
Rich Lilja
Posted on Feb 07, 2009
Looking to buy touch screen faceplate
Try audiovox.com. You should be able to find a way to contact them there. Audiovox now owns Jensen.
Oct 04, 2012 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
Can't control sound ...Gets LOUD.... Audiovox not helpful to date
actually there would have been some short circuit in the connections...
that would have affected the sound system...
so only you get the spikes.....check for the affected parts and replace them
Apr 11, 2008 | Audiovox VOH1502 15 in. Car Monitor
Where to buy a Replacement TouchScreen for my Jensen UV10
You can try going to audiovox.com and see if you can contact them that way. Jensen is now owned by audiovox.
Aug 31, 2012 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
I purchased a second hand vehicle equipped with what i believe is an audiovox alarm system. The alarm likes to go off at random times and i cannot figure out what is causing it. The car is a 97 vw gti vr6....
It probably needs to replaced. Audio Vox has several models that have window breakage sensors. These sensors are notoriously unreliable and do this quite often. I would replace the alarm itself.
May 14, 2011 | Audiovox Car Audio & Video
How do i buy a remote
try audiovox.com. audiovox owns jensen.
Jun 14, 2010 | Jensen KVM-64 Car Monitor
I have an Audiovox starter, model 5BCR03 in a car I bought and I can't get it to start the car. What is the button sequence to start the car?
a non specific general answer would be to make sure you unlock the doors, if that's a feature on your remote, then press and hold the start button for a couple seconds. then wait about 5 seconds, the parking lights should blink and the car will start. if this doesnt happen, check audiovox online and see if they have a user's manual for your product, if you cant find it, there should be a tech support phone number or just a general customer service number on their website you can call.
Feb 16, 2010 | Car Audio & Video
Tech Support for CCS-100
Hi! I've got my Audiovox ccs-100 installed in my Duna Weekend Diesel car. But it just doesn't work. I don't know if it's because I connected the vacuum to the brake servo or what! Can you help?
Aug 01, 2009 | Audiovox Car Audio & Video
Audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Sep 11, 2008 | Audiovox Car Audio & Video
Audiovox VOH1502 15 in. Car Monitor Logo
282 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
isaac johny
isaac johny
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
