I have seen your posts in both GE and RCA forums about the "no video/no audio" but have the on/off LED blink slowly 3 times and then go off.
I have also asked the FIXYA website team to allow you "GURU"'s to combine similar issue together in a thread so we dont have 80 threads/issues when there might only be 6 or 7. I hope they can help you on that.
Assuming you have the same set D52GW12 and the same exact problem as me I am hoping that this will work for me as well. Can you tell me the part number of the flyback that you picked up? Is flyback a solderless part? Should take care with the Capacitors?
Thats usually a flyback issue with Thomson. Thats a good suggestion with combining threads. I have often thought it would be great if we could have a way to list fault by Chassis . So people could go to their models look up the fault/ sympton and see the diagnosis for that sympton. Thanks for your input pete, and let me know if you need more help.
Was this helpful?
Yes
No
Popular Solutions for GE D52GW12 52 in. Rear
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
Magnavox model Fp5230 W104 Chassis PTV620-AJ01 Power light comes on and stays on, can hear tv kick...
(More)
Magnavox model Fp5230 W104 Chassis PTV620-AJ01 Power light comes on and stays on, can hear tv kick on inside. Audio works but no picture at all.
When turned on the green ligth goes on, the button lights but it goes of in a few second, then by...
(More)
When turned on the green ligth goes on, the button lights but it goes of in a few second, then by itself it starts again & goes of again this will do about three times the it goes off, If I wait a few minutes I can switch it on but it will do the same thing as before (On & Off) sometimes it makes a sound & it smells as if there where a wire burning the insulation, this GE is 5 years old.
the picture on my d52dw12 is bowed in significantly on the sides and slightly on the top and bottom....
(More)
the picture on my d52dw12 is bowed in significantly on the sides and slightly on the top and bottom. The color is fine and the picture is pretty good otherwise except for when I turn it on after being off for awhile its blurry but soon clears up.
