Question about RCA OPAL M4001 MP3 Player
RCA OPAL 4008 CAN'T SYNC SELECTED
JUST RECENTLY I'VE HAD PROBLEMS ADDING SELECTED MUSIC FROM WINDOWS MEDIA PLYER TO THE OPAL(PURCHASED 3 MONTHS AGO).
MY EDITED LIST OF FILES WILL COPY AND FULLY COMPLETE (NO ERROR MSG); THEN THE OPAL PLAYER WILL DISCONNECT... WINDOWS MEDIA WILL SAY NO PLAYER IS CONNECTED... ? I HAVE PLENTY OF SPACE LEFT ON THE PLAYER.. WHAT IS UP?
  • Anonymous Feb 07, 2009
    RCA OPAL 4008 CAN'T SYNC SELECTED problem
Also, what personally happened to me was that I had accidentally taken the RCA Product Detection off "Start with Windows" when I was cleaning up ****.
If you don't have the RCA Product Detection program running, your mp3 player will keep disconnecting and reconnecting.
It worked for me at least. Let me know if this helps.
Posted on Sep 09, 2009
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 25, 2008
SOURCE:
Installing to my computer
Downloading Music to MP3 Player
Hi jlone71
1...You must download and install Windows Media Player 10 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Plyer 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your data cord.
6...Media player should recognize the MP3 player and sync with it.
7...After it is synced with the computer,you can add the music you have installed into Media Player to your MP3 Player.
Free Answer...Please take time to rate me
May 23, 2011 | RCA TH1802 MP3 Player
I can't download music files from my computer to my Opal RCA MP3 player.
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 15, 2011 | RCA OPAL M4001 MP3 Player
I have recently bought a Phillips gogear 8g mp3 player and I just want to ask (since I don't have a cd software or a manual that came with the product) how do I add songs into my mp3?
you can simply use drag and drop method to transfer music from your computer to your MP3 player. You can also use Windows media player 10 to transfer music. Make sure to use version 10,. Version 11 doesn't work.
Transfer music via Windows Media Player 10:
1.Hook up your GoGear to the PC via the supplied USB cable.
2.Plug your GoGear into a power outlet with the supplied AC adapter/charger.
3.Launch Windows Media Player 10.
Note: Once the device is connected to the computer, all audio or radio playback will stop.
4.Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
5.Click "OK" to close the windows.
6.Click the "Sync" tab.
7.In the "Items to Copy" pane, from the drop-down list, click the playlist, category, or other item that you want to copy.
8.Click the check boxes next to any files you want to copy.
9.In the "Items on Device" pane, from the drop-down list, click on PhilipsGoGear for where to copy files to.
10.Click the "Start Sync" button.
11.The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
12.Repeat steps 2-5 for any other items that you want to copy to your portable device.
13.Once the transfer is completed, close Windows Media Player.
14.Unplug the GoGear from the PC and enjoy the music on your GoGear.
Ok, you can download all the software and drivers from this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=HDD_AUDIO_JUKEBOX_SU&cat=MP3_MEDIA_PLAYERS_CA&session=20110319225449_121.241.4.111&grp=SOUND_AND_VISION_GR&ctn=HDD1830/17&mid=Link_Software&hlt=Link_Software
Hope this helps.
Mar 19, 2011 | Philips GoGear HDD1830 MP3 Player
How can i get itunes to download on my phillips gogear 4gb?
  1. Hook up your GoGear with the PC via the supplied USB cable.
  2. Make sure you connect your GoGear micro also to the main power supply.
  3. Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
  4. Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
    Click OK to close the windows.
  5. Click Sync.
  6. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
  7. Click the check boxes next to any files you want to copy.
  8. In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files to.
  9. Click the Start Sync 051028091952_1760.gif button.
  10. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  11. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  12. Once the transfer is completed, close the Windows Media Player
  13. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
  1. Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
  2. Launch Windows Explorer.
  3. Drag and drop your music files into the music folder of your GoGear.
  4. Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
Jun 10, 2010 | Philips GoGear Flash MP3 Player
How to download music from computer to my philips gogear audio player
  1. Hook up your GoGear to the PC via the supplied USB cable.
  2. Plug your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Media Player 10.
  5. Click "OK" to close the windows.
  6. Click the "Sync" tab.
  7. In the "Items to Copy" pane, from the drop-down list, click the playlist, category, or other item that you want to copy.
  8. Click the check boxes next to any files you want to copy.
  9. In the "Items on Device" pane, from the drop-down list, click on PhilipsGoGear for where to copy files to.
  10. Click the "Start Sync" button.
  11. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  12. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  13. Once the transfer is completed, close Windows Media Player.
  14. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Note! You cannot transfer pictures via Windows Explorer, for pictures you need to sync them using Windows Media Player.
  1. Connect your GoGear to the PC via the supplied USB cable.
  2. Connect your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Explorer.
  4. Drag and drop your music files into the Media/Music folder of your GoGear.
  5. Once your music has been transferred to your GoGear disconnect it from your computer and you are ready to listen to your music.
if this it was helpful rate my solution and vote me thanks
Jan 06, 2010 | Philips GoGear HDD1830 MP3 Player
Transfer media
A guide in how to transfer media for the RCA Opal M4001 see this manual in pdf format: manual for RCA Opal M4001
For more help on for this device see the support site:
support for RCA Opal M4001
When using Windows Media Player 11, a short description how to deal
with putting media on the device:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Note; convert video with the RCA video converter on the computer
before transferring it onto the player.
A download can be acquired with the next link:
download RCA video converter
1. download the execute file
2. install the converter by clicking on the execute file:
" rcasmvconverter_v1.6.2.0.exe "
Sep 12, 2009 | RCA OPAL M4001 MP3 Player
How do i transfer all my music video's from my music file to my opal rca mp3 player when i plug in my mp3 player.
This unit supports windows xp and vista Just have windows media player locate all your audio and WMA compatable videos. Then use the sync feature at the top of your windows media player to create a sync list on the right hand side by dragging your stuff over to that area .Use start/sync button in the lower right corner this should get you loading your player!!
Jul 02, 2009 | RCA opal MP3 Player
My RCA Opal M4002 is not working with windows media player
Make sure its set to sync to windows media player and that you are using Windows Media Player 10 or above
Jan 06, 2009 | RCA OPAL M4001 MP3 Player
Mp3
if it doesn't sync, don't worry just open the folder where the music files are stored on your computer, connect your Sony Walkman to your computer and highlight the music files you want to add to the Walkman and select (copy these files) a windows will open for you to select the place you want to copy to, select your mp3 player and click on copy to copy the selected music to your Walkman
NOTE: if you Sony Walkman has a specific folder for music files, you need to move the songs you copied from your hard drive's music folder to the music folder on your mp3 player for the player to recognize the songs in order to play.
Dec 26, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Just installed nero 7 software on my comp. and really messed up all my music files. all my saved files have lost there names & are know numbered tracks of nero media type. Same applys to media i...
hi sir,
by default, you have a music player installed on your system or maybe using windows media player before nero 7 was installed, unluckily, when you did installed your nero 7 it has it's own music player. by the time nero finishes the installation, nero prompts you what media types you are using, by default, nero had selected it's own files types...thats why your music compilation and playlist messed up.
in order to get things back, just right click any music files you have, go to properties, click change for types of file then select the application you want play with your music.
Sep 04, 2008 | Computers & Internet
RCA OPAL M4001 MP3 Player Logo
205 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
