Question about GE Spacemaker WSLP1100D Top Load Washer
My washer is leaking...
Hello!
My washing machine is leaking water from underneath the machine. I have checked the rubber washers and they are fine. Please help me...I'm trying to be Martha Stuart and Mike Holmes in one and getting no where fast.
The brand of washer/dryer is: General Electric Spacemaker. They're stackable.(If that helps.)
Thanks for your help,
Kate Paylor.
My washer is leaking out the bottom, it isn't overflowing...just leaking out the bottom. Dear Lord please tell me why...
  • 1 more comment
  • SHIEKA Apr 22, 2008
    WASHER IS LEAKING FROM THE BOTTOM RIGHT SIDE
  • jawelch Jun 04, 2008
    Sounds like I have the exact same problem. Very slow leak that gets slightly worse as the water level increases...
  • boudreaux73 Jul 16, 2008
    My washing machine is leaking from the bottom of the machine. I have taken the water pump/spin pump off and put it back on. The machine is still leaking.
  • 5 Answers
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Posted on Jun 19, 2008
2 Suggested Answers
vest6
  • 196 Answers
SOURCE: My washer is leaking...
There are several items that can leak on the inside. I may be of some service to you. I need to know the model and serial number so I will know wich machine is being worked on.
Posted on Jan 09, 2008
Bosch Axxis washer leaks underneath
take top off at back and check valve ,it should be at the top . Also check front rubber boot for rips, this is a big problem in all brands.
Nov 21, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Water leaking from underneath washer
This happened to us on an AEG auto washer, first check rubber seal for splits or perished rubber, if that is ok it could be either a blocked filter or, as in our case the pump was split. As our washer was 18 years old we binned it and bought a new one.
Oct 13, 2011 | Frigidaire GLWS1349A Top Load Washer
When I hook of the water hoses to the back of washing machine and turn on the water, water spews out of hose
Hello Ifox5858,
I understand that when you hook up the hose to the back of your washing machine that the water comes out of the hose. The problem that you are having may be because of washers are missing out of the hose ends. You need to take the hoses off and look and see if you have rubber washers in the side that is leaking. The washers are standard water hose washers you can buy at any hardware store.
1. Place washer in hose
2. Install hose hand tight
3. Turn a quarter turn with wrench
4. Turn water on check for leaks if leaking slowly turn tighter to leak stops
This should fix your problem.
Thank you for choosing FIxya.com
Justin
Mar 16, 2011 | Fisher and Paykel Washing Machines
Water leaking underneath
hello you may have a hole in the door seal open the door check the rubber door seal, if this ok the check the hose that connects to the pump
regards
shaun
Aug 30, 2010 | Whirlpool LHW0050PQ Front Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaks water onto floor while in use
It sounds like a water hose is leaking or has a split in it. Check the water in-take hoses on the back of the washing macine, to see if its leaking or split. If they are leaking, unscrew the hose and check or replace the rubber washer, thats in the brass screw-in part. Next, unplug the washer power cord, unscrew the intake water hoses that are in the back and turn the washer on it's side and check the water hoses underneath the washer. They may be loose or split. Any hardware store should have these hoses in stock, like Lowes or Home Dept, or your local "Do it center".
Jan 19, 2009 | Washing Machines
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Jan 09, 2008 | Washing Machines
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
GE Spacemaker WSLP1100D Top Load Washer Logo
847 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
