Question about Rio Go Video GV6650 Dual Deck VCR
Repair and parts info
Spills tape, take-up reel does not turn, dont completely unload tape
  • bump1 Apr 11, 2008
    where can i buy parts for gv6650 vcr? thanks
  • 4,234 Answers
This unit needs an overhaul. Specifically, there are belts and idlers that should be replaced. The rubber has dried up a bit and is slipping. This is a common maintenance item and should cost about $20-$40 in parts plus hte local labor charge.
Dan
Posted on Apr 11, 2008
  • ABRsvcs Apr 11, 2008
    The Govideo uses generica parts as the mechanism is a Samsung one. I don't have the reference with me at the moment, but you can call any electronics parts distributor and they will have the cross for you. There will be 2 belts and idlers (1 for each mechanism). I think that your model is a direct drive loader, but if not, there will be an extra belt per unit for the loading mechanism.
    Dan
My unit has a cassette tape in it. When I power it on, it starts to begin functioning, then, after 3 to 4 seconds, it powers off. I have tried the reset button. Any ideas?
is it the same tape that does this repeatedly. try winding the tape on if it is loose some vcrs will switch off rather than functioning and mangling the tape.
May 30, 2015 | Televison & Video
Parts for a govideo model # GV6650
Contact go video, and ask for the service manual. You need the part numbers to replace them. Or ask replacement to go video.
Apr 09, 2008 | Rio Go Video GV6650 Dual Deck VCR
Tape ejects and will not play
the tape player will first look to see that the tape threaded properly around the video and audio heads ... then it will check to make sure the tape take up reel starts to move before allowing it to continue .. if the take up reel doesn't move in a couple of seconds after insertion then the tape would spill out inside the machine and make a real mess ..in order to prevent that the machine ejects the tape.
take up reels often quit because the rubber wheels, belts or friction drive components have become hardened from age .. if the take up drive is not strong enough then it wont pull in the tape .. in order to prevent tape and machine damage the recorder ejects the tape .. that can also happen if the rubber parts have contamination or lubricant on the friction surfaces ... you can sometimes clean those wheels and parts using distilled water or special cleaning fluid .. dont use alcohol since that will remove elastomers in the rubber .. sometimes you can use a pencil eraser to clean up the friction surface by removing oxidized rubber... the proper fix is to replace the rubber take up reel drive parts if they are still available .. a rubber wheel liquid dressing is available that improves the surface for a while ..
the same problem happens in high humidity areas .. if the humidity is high enough then the tape tends to stick to the audio head and other guide parts .. if that happens then the take up reel will also stop moving .. warming or drying the tape and air (air conditioning or dehumidifier) can fix that but it takes a few hours ..
if a machine has not been run for a long time then sometimes just by cycling it many times trying fast forward and reverse can clean up the drive parts enough to get it working .. but do that on tape you can afford to lose .. be careful you dont end up with a lot of tape piled up inside the machine.
some late model high quality machines have a different drive mechanism that is more reliable .. sometimes you can find really nice machines at goodwill .. the better name brand ones may still have parts available .. the low cost units are considered disposable and are almost never worth the work that it takes to fix them unless you do it yourself .. the mechanism borders on genius but workmanship and mechanical cost cutting often resulted in machines that barely worked even when new ..
Mar 09, 2014 | Toshiba DVD/Video Cassette Recorder...
HOW TO REPLACE A VCR UNIT
The problem is a tape end sensor issue, or the tape up reel is not turning, remove top to verify.
Jul 27, 2012 | Televison & Video
Ihi i have a michigan brand brush cutter i bought online it does not have an arrow on reel so i dont know which way line feeds onto reel and also does the spring go on the base or under the bump i am...
On most standard weed trimmers, you load the line counterclockwise. This is with the inside of the reel facing up towards you. You see; once the reel is installed and the head turned over for operating, then the line unloads clockwise. The spring will go under the bump knob and set into the middle of the spool (or reel as you call it).
Oct 14, 2010 | Garden
Rewinding a tape
Theres a rewind ,fastforward clutch inside the tape mechanism thats worn, the brake for the supply reel in not releasing completely, or theres hair -dirt- or gunk under the supply reel, or the drive belt needs to be replaced. Now If this wasent part of a tv set combo I would say take it apart and have a peak at some of the things I mentioned. BUT theres extremly HI VOLTAGE inside this puppy and if you dont know the saftey issues related to this , I would highly recommend getting a pro to assist you in this repair. Good Luck
Jun 27, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Apr 04, 2006 | JVC HR-J461MS VHS VCR
Tape won't load.
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but one of the reel The takeup reel is turning properly but one of the reel rotation sensors or its electronics is defective. As a test, check to see if the tape counter is changing at any time during the loading and
Dec 12, 2005 | Emerson EWV603 VHS VCR
Doesn't repond to buttons and stuck on rewind
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but one of the reel
Nov 29, 2005 | JVC HR-VP670 VHS VCR
The unit will fast forward and rewind, but won't play
Nov 22, 2005 | Sharp VC-H810U VHS VCR
Rio Go Video GV6650 Dual Deck VCR Logo
85 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
SHARCNET-USA
SHARCNET-USA
Jaime Hernandez
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
