Question about Crown CE1000 2-Channel Amplifier
Ce1000 Dan, thanks for taking the time to reply, I'll let you know how it goes when I get time to put'er on the bench. Who ever says once you retire you've got plenty of time on your hands is greatly mistaken! Jim.
  • 4,234 Answers
Feel free to request specifics if needed.
Dan
Posted on Apr 11, 2008
I have installed my new Bosch front loader on a bench and levelled as per instructions and spins perfectly empty but goes beserk with any clothes inside
(How solid is the bench- probably not as solid as the floor?)
Although you say it's level I would recommend you try my method to make absolutely certain.
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor/bench (!), and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 20, 2011 | Bosch Washing Machines
I'm having trouble with my music play er pls. help !!! :(
Hello i hope u 'll be fine.... thanks for using fixya.
This problem is usually occur when music player don't load data of phone or memory card itself
  • Turn on your cell, when it 'll be on, Starting music player it 'll take some time to refresh
  • Now do in the options of music player
  • Second option 'll be music library open it
  • Go down there 'll be a last option Update Library,Press ok, it 'll take some time and hope it 'll load all your music and all music files 'll show in track list.
Enjoy
I hope this solution will work and helpful 4 u. Best of luck
Please do rate if if it is helpful
THANKS
Mar 01, 2010 | Nokia 3110 Cellular Phone
C 124 c224
Most shops charge a fixed fee for labor and add in the parts cost. The capacitor cost can be anywhere from $1 each to over $10 each, depending upon their value and voltage rating. Typically I would charge between $80 and $120 for labor with a unit like this. Since this is a part time job for me because I like the work, my charges tend to be less than a full time shop.Realistically, this type of repair would cost between $150 and $200 and should include both a warranty for the work as well as bench burn-in time.
Dan
Oct 21, 2009 | Crown CE1000 2-Channel Amplifier
I have a Crown CE1000 power amplifier. I turned it on the other day and I seen a bright flash inside of it. Now the fault lights are blinking and it won't work. Is there something that I can look for or is...
Unfortunately Crown amps are not the easiest to repair as they utilize multiple levels of amplification. Since you saw a flash, a resistor probable smoked, I would recommend that you bring this to an authorized service center.
Dan
Mar 17, 2009 | Crown CE1000 2-Channel Amplifier
Ps2 mega memory card
I would say that the memory car is no go, or the memory card has been er erased.
Nikki2913
Sep 29, 2008 | Video Game Consoles & Games
CE1000
You have bad connections at the inputs. If you can solder, carefuilly remove the board that has the input connector and resolder the jack onto the PC board. This should be done ASAP as with the connection loose like that the circuit board traces are soon to break.
Dan
Aug 18, 2008 | Crown CE1000 2-Channel Amplifier
Battery runs down after driving vehicle
Sounds like you need an alternator. Start the car and hook a volt meter to the battery. If it is not charging over 13.8 volts it's alternator time. Thanks....Dan
Jul 27, 2008 | 1997 Chevrolet Camaro
Crown CE1000
Hi waveybnc
The fan has failed, or is clagged up with dust. Remove it and clean it first. But best to just replace it. They are not that special and there is not alot that stops them from working. You can get a replacement device for the amp from Crown direct, or once you know its dimensions and power requirements, from here.
Thanks for using FixYa. Please rate my advice to you here as FixYa if it helps you.
regards
robotek
May 25, 2008 | Crown CE1000 2-Channel Amplifier
CE 1000
Look first at the output transistors. Those are the most likelt defective parts. Due to the odd design of the output section, Crown amps are difficult to repair. If you get lucky, only the outputs are smoked. Also, make sure that you change all of hte transistors for the channel that has a bad one.
Dan
Apr 09, 2008 | Crown CE1000 2-Channel Amplifier
Clip led
That particular channel is blown. These are not the easiest units to repair. Given that this is a commercial amp, I would recommend that this unit be brought to an authorized Crown service center for repair. Expect parts cost in the $50 range plus the labor charge.
Dan
Apr 07, 2008 | Crown CE1000 2-Channel Amplifier
Crown CE1000 2-Channel Amplifier Logo
51 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
