Samsung LA52M81BDX Picture Problem
On turn-on unit displays an image and a buzzing noise is emitted. After a few seconds, image and noise disappears but sound is OK. Looking closely at the panel a very dark image can be seen. Problem is intermittent and only occurs if the unit has been off for awhile (or cold).
Any help appreciated
    Master:
  • 788 Answers
If you see a very dark and very faint image it usually indicates a problem with the backlight inverter. That device take the relatively low voltage that runs the TV and ramps it up to power the cold cathode lamps in the panel. It's like the ballast in fluorescent lights. Not sure if Samsungs calls it the FL Inverter or something else I am looking into it now. You could possibly disconnect the power supply to the inverter and see if the noise goes away, then you would know to replace the inverter board. I'll have more in a bit.
Posted on Apr 11, 2008
  • Dean Joly
    Dean Joly Apr 11, 2008
    Not much luck in finding parts for this TV. I would consider having it repaired if I were you, hopefully it's under warranty. Go here to find a service location near you: http://www.samsung.com/au/support/repair...
    You are in Australia right? This TV seems to be an Australian model from my searches.
  • 796 Answers
May be some of the transistors on the display are not gettin the needed supply...
i mean there is come loose connection in the main board...
try to check the connections
  • 4,234 Answers
There is a bad connection on the inside. The unit is detecting excessive current draw when you hear the buzzing and it shuts down to prevent damage. If you are not comfortable working on this unit, bring it to a servicer. This should be a simple fix and cost the minimum labor charge for repair.
Dan
Yamaha YSP 800 Digital Sound Projector constantly emits a low buzzing noise (even on mute). My only remedy to drown out this interference is by ramping up the volume, which sometimes actually fixes the...
Do you have any other nearby devices that emit radio frequencies like a wireless router or a cell phone? I have had issues with buzzing on some of my speakers when my cellphone was nearby.
Oct 15, 2013 | Audio Players & Recorders
MY TV STARTS EMITTING A BUZZING SOUND AFTER IT'S BEEN ON AN HOUR OR SO. It is a Samsung DLP model HLP5063WX/XAA.
Its likely to be the color wheel which when fails can do several things: A high pitched whine or what is often described as a fan like sound.
Since the set monitors the speed of the wheel if it slows down even a little image may look odd or dark.
you can at worst hear a grinding sound and it means segments in the wheel are shattered or missing
Good news is it is readily available and many average people can replace it---you tube even has video instructions for most of the Samsung models for this.
Only two models were made and Google the model number with Color wheel to locate the one your set uses.
Dec 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Motor power
you need your power supply repaired. buzzing sound is a bad disc capacitor. blank picture can be bad mofsetts, invertor and bad capacitors.
Dec 27, 2009 | Samsung 732N 17" Monitor
Samsung LN-t5265f picture turns off after a few seconds hear buzz
You have a bad Power supply. Have a trained Samsung tech replace the Power Supply.
Jul 02, 2009 | Televison & Video
GATEWAY BUZZING VERY LOUD AND PICTURE GHOST LIKE IMAGES
i have the same problem with the noise and the video quality is ****, my friend gave it to me to see if i could fix it, i took it apart and the sound is coming from either an orange thing or a capacitor, could it be an overload capacitor where the sound is a bunch of sparks flying through the dielectric?
Jan 17, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Open Questions:
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
