Question about Kenmore Elite HE4 Electric Dryer
Locked My dryer has locked out How do i get it back and running i tried to unplug it for a while to see if it would reset but has not. help
    Genius:
  • 1,073 Answers
Hold in the far right button for 4 seconds , the machine is in child safety lock this will fixya
Posted on Apr 11, 2008
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
'control locked' button on. We unplugged the dryer and plugged it back in. Cannot reset to start the dryer.
have you tried holding the cancel button for 10 seconds message me back your model number if this does not work not sure what type we are talking about unless i can see the unit Thanks Rick
Jan 29, 2011 | Dryers
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
Nov 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
The light for Control Locked is on and it will not start
someone has inadvertently locked the control panel. to unlock it, press the "end of cycle signal" button for 3 seconds or until the lock light goes off
Aug 29, 2009 | Whirlpool GEW9250 Electric Dryer
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
