Question about Bose Companion 3 Computer Speakers
Bose Compoanion 5 Problems
Hi, in fact it was the same Computer and I tried everething reg. audio setup. Bose told me today that something broke with the internal power supply, although the device worked and was detected by the system properly. The only thing was that no sound was coming at all. I hope they´ll fix it within their warranty and - most of all - it will work then. I´ll let you know. Thanks
Kk bt i ain t gt a warranty lol
Posted on Apr 13, 2008
Hi i have the Bose companion 5 speakers today there was a power cut in my flat. after that my speakers are not working anymore. the thing is that the led on volume control is on (green) and my pc...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 30, 2011 | Bose Companion 5 Multimedia Speaker System...
I have a bose companion 3 series ii my base speaker has an broken audio input that i'm trying to fix can anyone help me Please!!!!
Yes you can fix it but need a soldering iron and tin and the part that will change. Get everything in radio shack or similar store. If you don't now how solderin go to this link: http://www.youtube.com/watch?v=Rm28jkKGMz4
Good luck
Dec 15, 2010 | Bose Companion 3 Series II Multimedia...
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
Speakers causing computer problems companion 5
Hi, I have these also & mine occasionally go to the red light while the PC is on.. Are they visible in the 'Sound' in control panel as Bose USB Audio' is this set to default? Is the USB kept in the same socket? & are they too close to other speakers?.. Let me know
Mark
May 04, 2010 | Bose Companion 5 Multimedia Speaker System...
The right speaker on my Bose Companion 3 works for a while then just stops working. I haven't changed anything on my computer setup. I checked and the plugs are inserted tightly.
Can you hear anything from it right now, such as scratching noise or something, if you can hear something, then check the audio input cables, or the output to the right speaker, try turning it or something.
If that method didn't works, then possibly there's two conditions:
1. Your right speakers burned, try replacing it with the new ones.
2. Your power board half damaged, the right channel is damaged or something.Maybe the IC's burned or maybe just some minor electronics parts that is not working properly.
Dec 09, 2009 | Bose Companion 3 Computer Speakers
Can I hookup a Bose 901 EQ to my receiver and amp?
Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
Put that old amp back to work.
This is exactly how mine are connected.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Aug 19, 2009 | Bose 901 VI Main / Stereo Speaker
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Apr 10, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Problems
email support@bose.com or contact a Bose Support Specialist in Germany; or call US support at 1-800-367-4008. Something very odd is happening here. You are using the same laptop, correct? If not, let me know, as there are some things to try. If Bose has a solution, I'd love to hear it.
Mar 19, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
89 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
