Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Wirlpool fridge leaking from filter
I have a wirlpool estate fridge with a front loading filter down on the bottom of the unit. it is leakng all over the floor. it looks to be leaking from the area where the two hoses go into the back of the filter. could it be that the filter is just clogged and needs replacing or is the problem probrably in the housing
  • javajava Apr 26, 2008
    leaking not from the lines going in or out of filter but at rear filter dripping constatntly filling tray flooding can remove filter no problem no leaks does filt
    \er need replacement or is there a clogged line entering or leaving filter Caren
  • smd4204 Jul 21, 2008
    lines into the filter housing leaking, do we have to replace the whole unit or just the lines?
Had same problem and had sears tech out. Lines attach to housing with what he called pinch gasket instead of threaded coupling. Had to replace filter housing as gasket can't be purchased seperately.
Housing $50 gasket probably would have been $.50.
Posted on May 13, 2008
    Genius:
  • 1,073 Answers
Filter housing or the lines that are connected to the housing
have had a few of the lines that split i know it is hard to see under the fridge but you can remove the filter housing and unbolt the water valve from the rear of the ref and wangle thelines and housing to the rear of the ref to see where the leak is at
Posted on Apr 11, 2008
Why is my LG front loader leaking from bottom front of washer?
When cleaning the filter you may have dislodged the o-ring seal on the filter unit. Check the condition of the seal or if missing replace it with a new one.
Sep 13, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water leak coming from under my washer wirlpool duet. what would be causing that?
you can remove the bottom panel in front on this unit... the screws are near the floor then that bottom piece can be pulled away... there is a clean out next to the pump assembly run some water and see where water is coming from most likely a hose or pump assemble is leaking ..check all hoses like i said run unit and you should be able to use a flashlight and find the culprit water leak...
good luck to you
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE THE ESTATE FRIDGE AND I CANT SEEM TO FIND THE WATER FILTER SO I CAN CHANGE IT ?WHERE WOULD IT BE ?
usually the filter is under the refrigerator side .open door look behind bottom panelor in frig compartment behund panel
Aug 23, 2010 | Estate TS22AFXKQ Side by Side Refrigerator
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Front fork seal is leaking
Yep, drain the fork oil, raise the front wheel in the air, remove the front wheel and axle. The nut to remove the lower leg is at the bottom, hidden by the axle. If it still leaks after seal replacement your fork tubes and lower leg sliders are worn out. Reassemble and remove the top fork cap. Pour in the correct cc of fork oil and ride.
Apr 14, 2009 | Harley Davidson FLHTCUI Electra Glide...
Water leaking out onto floor
Scott you are dead right with the drain. If you open the freezer door and look inside at the back in the middle of the plate at the back on the very bottom there is a small hole. This hole goes all the way down through the fridge and then finally to a dish that sits ontop of the compressor via a hose. If any part of this hose is blocked then it will find an easier path which is uually out the front and on the floor. The most likely culprit would be ice. Leave it off for a half a day or so so the ice melts then turn it back on and test it for a week. Do not turn the thermostat up very high otherwise the problem will reoccur.I hope this helps.
Sep 28, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
270 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
