Panasonic TX-25ck1l screen goes black and red light flashes
  • 4,234 Answers
Does the red light flash any particular repeating count? The set is in shutdown because a problem was detected. This is done to prvent further damage. Please update this with the count, if there is one as that would indicate the circiut where the problme was detected.
Posted on Apr 11, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
TV stopped working, how can I fix the problem below?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Sep 12, 2014 | Panasonic VIERA TX-L32X5B 32" LED TV...
Panasonic tv PT50LC13 has no picture red light flashes when i turn it on green light flashes and turns off
This model was recalled by Panasonic-----massive recall. Start by having the lamp examined or tested---that is the place to begin.
Oct 17, 2012 | Panasonic Televison & Video
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
May 03, 2012 | Televison & Video
All the troubles I've seen with this model are because of the LIFI lamp. Panasonic warrants the lamp assembly for four years from date of purchase. Call Panasonic toll free hotline or go online for an authorized warranty shop. Good luck
Bill W
Mar 13, 2011 | Panasonic PT-56LCX70 56" HDTV
Re: my 32" Panasonic Viera Lcd-- The red power light comes on for a few seconds, then goes off for another few seconds, then starts blinking. The screen stays black and there is no sound. Bob in LB
id suspect its going in to a shut down mode its likley a power supply problem
but there are inverter boards that can cause this as well
you will probably want to find a servicer in your area to assist with this repair
Oct 22, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
having problem with sony television the screen when its turn on no images found just found red color on the screen..
Feb 01, 2009 | Panasonic TX-42PT10 42" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
