Question about InFocus ScreenPlay 4805 Multimedia Projector
Wiring fan direct
What all do you need to wire the fan direct where do you tie in
  • kazoola Apr 18, 2008
    the fan doesn t get enough current from the control board
    i want to know is there a way to wire diretly from another source
  • sheridan1952 May 11, 2010
    What do you mean, wire direct? The fan is plugged into the main board.
  • 26 Answers
If your main fan is not turning or not turning reliably, most likely your fan controller on the main board has failed. I don't have any information on the voltage requirements for the fans. The service manuals for the Infocus projectors does not have any schematics so I wouldn't know where to pull power from without harming anything else.
Sorry.
Posted on Apr 18, 2008
Remove light governor
I installed my Hunter Ceiling Fan a little over a year ago. A few nights ago my wife told me the lights in the ceiling fan blinked a few times when she turned it on. Over the next few day the problem got much worse. When I turned on the light switch, the lights would not turn on. After a few minutes the lights would begin to flash, like a strobe light. This flashing would last for about a minute.
This morning I removed the light kit. I noticed the watt regulator, part 98480-02. I connected the wires directly that were wired through the regulator. So far, the light now works fine!
Jun 11, 2014 | Hunter Ceiling Fan Light Switch Control
Wireing diagram for 2014 crusader 295rst
Wiring diagrams are not available as the manufactures to not publish them. You will probably have to find the closest 12v power source and tie into that in order to install fans.
May 23, 2014 | Prime Time Manufacturing 2013 Crusader...
I need a wiring diagram of the Hampton Bay fan with light. The fan is black and white and the light has a blue wire. I believe the blue should be tied to the black, am I correct. Thanks
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
Sep 10, 2010 | Hampton Bay 24002 Ceiling Fan
Ow do you add on an electric fan to assist the belt driven fan using installation kit that says use zip ties.i have a cooling problem on a p30 chevrolet that is pulling and hauling a great deal of weight....
Usually there is a plastic/foam washer on both ends of the ties.You push the plastic ties through the rad fins and through the aftermarket fan or trans cooler or whatever you want to attach.
You should have installation instruction in the package?
There may be a video on youtube?
Jan 15, 2018 | 1987 Chevrolet V30
How do I wire an in-line duct fan directly to my furnace so that it runs when my furnace runs?
Tie the power from the larger room air blower to the duct fan. There may be a few other wires that energize when the blower starts that are there to change your blower speeds. The easy way is to use one of them to power the new fan.
Feb 07, 2010 | Heating & Cooling
Would this work or burn out fans? Amps on one fan is 1.5 and the other is 5 amps I want to run a 12/2 wire from the panel and to the duplex switch and tie it into a 12/3 wire that goes to switch to...
Yes everything would work perfectly. I see no problems in your plan. Even if both fans were run off of one switch they would not burn out, the circuit it appropriately sized. You could even go a step down to save yourself some money and use 14/2 and 14/3 (supposing its only the fans running on the circuit). You can run up to 16 amps on 12 AWG wire and up to 12 amps on 14 AWG wire (80% of breaker tolerance). Also when it get to the fans use a wire junction box run your 3 wire cable in there and branch out to your fans from there with separate 2 wire cables. I believe that was your plan just wanted to clarify. Good luck!!
Jan 02, 2010 | Broan-NuTone Nutone Utility Exhaust Fan...
Tell me what you are wanting to accomplish. Are you wanting to run each fan off a separate switch in the same duplex box? The reason I ask is because you are using 12/3 wire to the fans. If you are just going to have 2 switches then you are only going to have power to each fan from each switch. Therefore there is no need to run 12/3 wire. 12/2 is all that is needed and you would simply tie the fan and light wires to that one power source at the light/fan. Now if you are wanting to have a switch for the light and another switch for the fan at each location then that will take 4 switches. You can buy double stack switches and have 4 switches in a double gang box. Is this new construction or old? Please explain what you are wanting and I will be more than happy to explain how to wire it.
Jan 02, 2010 | Microwave Ovens
Adding lite kit to 1980's solid state fan. Manual
the switch on the wall has to break the power to your fan and new light and the both must share but be switched independently at the fan. the 2 wires that the light were hooked up to should be tied to a pull chain and tied to the supply and not tied in with the wiring for the fan any longer
Nov 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Wiring a ceiling fan with light fixture. there is a black and white stripe wire, one black wire, one white wire and ground wire. Coming out of the ceiling is two black and one white. one copper. please...
The black and black with white stripe are for the light and fan respectfully. The white wire is your neutral. That leaves the ground to your copper ground wire. If you have two seperate switches to operate the fan and light then the two black and black with white will tie in to seperate black supply wires. If only one switch then they will tie in together to the black supply wire.
Sep 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceinlg fan
If your house has only a black and white wire, than you need to tie the black, balack and white striped wire to the black of the hous. You than have to use the pull chains on the fan when the switch is on, to turn the fan or the fan light on or off. If youre house had a red wire than that would be tied in with the black and white striped wire and you would have two swithes on the wall to control the fan and light instead of having to use the pull chains.
Sep 27, 2008 | Hunter 23852 Classic Original Ceiling Fan
InFocus ScreenPlay 4805 Multimedia Projector Logo
137 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
