Question about HP vp6320 Multimedia Projector
Hp vp6320 I replaced the bulb. Both warning lights are still blinking (temp and bulb) I tried reinstalling the bulb. No luck.
  • 1 more comment
  • philwong84 Jan 09, 2009
    Hi Tarolim, how can I reach you? My email address is philwong84@hotmail.com Thank you.
  • ThunderSlap Jan 18, 2009
    who's the guy who can fix projectors? i see all the posts but no contact info. ???
  • mvejar Apr 24, 2009
    My vp6320 projector's bulb warning light came on, I replaced the bulb, and the bulb warning light continues to blink. What to do? Called HP and they told me..."product is obsolete, we cannot support it, so go buy a new one..."
    Problem Solver:
  • 18 Answers
For sure this is caused by failed color wheel sensor. HP redesigned this assembly twice and the last design change worked very wheel. The new sensor assembly comes with new temperature sensor cable, focusing spacer. I am factory trained and I can repair the projector for you.
Posted on Nov 30, 2008
Tip
Replace HP VP6321 Projector Lamp Models: HP VP6321 / HP VP6320 / HP VP6310 / HP...
Models: HP VP6321 / HP VP6320 / HP VP6310 / HP VP6300
Here are the steps to replace an HP VP6321 Projector Lamp:
  1. Turn off the projector and allow it to cool for 30 minutes.
  2. Unplug the power cord.
  3. Press the release latch (1) on the lamp cover and remove the cover (2).
  4. Press the release latch on the lamp connector and unplug the connector (3).
5. Loosen the two screws (4) on the lamp module, and pull out the module (5).
6. Insert the new lamp module into the projector and tighten the two screws.
7. Plug in the lamp connector.
8. Snap the lamp cover into place.
9. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp.
10. On the projector, press Enter.
11. Advanced setup, then Reset lamp hours.
12. Press Enter.
The lamp module has now been replaced and the projector is ready for use.
I hope that helps.
________________________________
Download Hp VP6321 Manual here.
on Apr 23, 2010 | HP vp6320 Multimedia Projector
Blinking Temp and bulb light on HP VP6310
The color wheel sensor is dead. This is a common problem.
Jan 30, 2009 | HP VP6310 Multimedia Projector
HDCP compatible
There is no fix to this. basically HP did not make the HDCP very robust. It will DHCP with some DVD players, not all. HP is calling this a computer projector and down play the issue. No fix, try different DVD players. I had good luck with Toshiba HD.
Jan 05, 2009 | HP vp6320 Multimedia Projector
HP vp6320 projector ten seconds it shuts off
I had the same problem, the first couple of replacement bulbs i ordered worked fine but the last 3 i got, 2 of them have been faulty, i just sent them back and they replaced them. If its too late to send the bulb back you can go to the settings on projector, select lampsaver setting, its probably set at off, turn it on. Your bulb will be a little dimmer in this setting but shoud let the projector run ok.
Dec 01, 2008 | HP vp6320 Multimedia Projector
HP vp6320 projector
You need to replace the color wheel sensor. I can fix it.
My projector won't come on.
I answered this question many times. This is caused by a failed color wheel sensor. It faile gradually, first the lamp flickers, sometimes go dim for no good reason. Finally the lamp will not strike and you will get two red warning lights. I am factory trained and I stock the redesigned senor.
Aug 30, 2006 | HP vp6320 Multimedia Projector
HP vp6320 Multimedia Projector Logo
653 people viewed this question
Ben Johnson
